Xantia 1.9d poor running help please!
Re: Xantia 1.9d poor running help please!
What type of seal is it at the bottom of the filter housing?
Former Proud owner of a 1994 Citroen Xantia 1.9d and BX 19RD
Now driving an Alfa 159 but god I miss the Xantia!
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Im not sure what it is either but I beleve it can... tons of filter houses up here. You be welcome to a couple of them to try if you like..
the filter housing has an O ring around the underside of the housing...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Well, I think the plan of attack is replace the seal under the filter housing and while it's off seal up that white bit. Then put it back together and see if the bubbles disappear.....
Decided to try blocking up that white bit first before removing the filter housing to replace the seal.
Two coats of silicone later and it's running again. Only been out in it once so far and it seemed to run better. Couldn't see any bubbles in the clear line anymore after the short run. This morning after the same run (it ran badly) there were lots of bubbles winging their way down the tube.
I'll update again after a few more miles of testing
Well so far so good. Been about 40 miles or so today and it's behaved itself so far.
