2003 hdi c5 estate very rough ride quality
- swiveleyedgit
Re: 2003 hdi c5 estate very rough ride quality
Mine has 215/55/16's on at the moment. When they wear out I'm going to fit 205/60/16's, specifically Dunlop Blue response. I've run these tyres on the wife's Merc c class and they are brilliant, superb wet grip, low rolling resistance and the quietest ride I've ever experienced. They have a slightly bigger overall diameter than the 215's, 70 on the speedo is 71 and a bit, I think they will be a great match for a C5.
Bob
Current Citroen
2004 C5 2.0 Litre HDI VTR Auto
Current Citroen
- darbuck
- Donor 2023
- My Cars: 2008 Citroen C5 X7 Tourer VTR+ (138 BHP)
2007 Nissan Primera P12 1.6 T-Spec (110BHP)
2003 Citroen C5 Estate level 2 (110 BHP) 2.0 HDI
2001 Nissan Maxima QX 2.0 V6 - x 142
it definitely says on the placard 205/65/16's so im going to go half way and get 60's as the cost here is bloody ridicolous
thanks lads
thanks lads
Darren
I've got the blue response's fitted to my C5, very quiet I've got 15 inch rims on my car though.
CX GTI 2 Turbo (LHD) - Sorn
Bx Gti 16v
BX TZD Turbo - Sorn
C5 Mk1 LX 2.0HDi Estate
Mini Cooper D Clubman
Bx Gti 16v
BX TZD Turbo - Sorn
- swiveleyedgit
The cheapest option, they're generally half the price of 16 inch tyres. The difference in cost is hard to understand considering there's only an inch difference in wheel size. Mytyres are doing the 205/60/16's for about 80 odd quid at the moment which isn't too bad.SwissSPEC wrote:I've got the blue response's fitted to my C5, very quiet I've got 15 inch rims on my car though.
Bob
Current Citroen
Current Citroen
- darbuck
- Donor 2023
Got new tyres lads tracked and balanced discovered a lot of runout in the front wheels so put on the back massive improvement (205/60/16) much less road noise aswell unfortunately a lot of knocking coming from suspension but cant tell whether its front or back.
Sent from my ALCATEL ONE TOUCH 903 using Tapatalk 2
Darren
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1289
- Contact:
Common causes aredarbuck wrote:unfortunately a lot of knocking coming from suspension but cant tell whether its front or back.
Front = Drop links, cheep and quick.....shows mostly on the return after a speed bump.
Rear = Rear Arm Bearings, not cheep and a (can be) a PITA to change if you leave it to get worse.....shows mostly on compression as you go up a speed bump. If this, get it fixed as it will get harder to repair and cost more.
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- darbuck
- Donor 2023
How are you sticky it rattles like a bag of spanners on bad roads well more of a clunk what kind of noise do bearings make oh by the way where do you support the rear on these with stands
Darren
- Stickyfinger
AX, little Daffodil
- Contact:
If it rattles from the front, it could be the drop links (commonly) or other joints, the rear swing arms either creak and groan when you raise/lower the car or go BANG on speed bumps ....test by pushing down on the rear hard and looking to see if the rears "lean in"
I always use the sill/jack areas for axle stands, all other times it goes on a ramp with slide jacks
Mine makes a creaking noise if I stand on the boot lip and jump up and down, and a cracking noise on bumps on the road. I imagine that the arm bearings are shot. Both rear wheels look to be vertical though and it handles fine.
Sent from my SM-N9005 using Tapatalk
- My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1204
That's the right sort of noise for them.
- darbuck
- Donor 2023
She doesn't creak but she seems to rattle for every little bump
Darren
- Stickyfinger
AX, little Daffodil
- Contact:
Shoot it and be kind ....northern_mike wrote:Mine makes a creaking noise if I stand on the boot lip and jump up and down, and a cracking noise on bumps on the road. I imagine that the arm bearings are shot. Both rear wheels look to be vertical though and it handles fine.
Naaa mate, just get them done asap
- Stickyfinger
AX, little Daffodil
- Contact:
from the front or the back commeth this rattle Sir ?darbuck wrote:She doesn't creak but she seems to rattle for every little bump
Usually this would be an issue on a cheap car, which it was, which would have me sticking it on eBay, and likely getting near as damnit what I paid for it. However, for once, because I like this car so much, and because we screamed across Belgium and a little bit of France in it, I'm going to give it a second lease of life and actually get it repaired.
I've already contacted my favourite Citro-boffin to arrange both sides to be done..
- Stickyfinger
AX, little Daffodil
- Contact:
how much did he quote ?
