very poorly xantia 1.9td...help!
Re: very poorly xantia 1.9td...help!
Ok. Thanks Macplaxton.
as Max says
but if you do use a petrol tester on a diesel can you video it and put the youtube link on here
Regards, malcolm.
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Im sure xud 9te units are not as high as 23:1 .. n/a non turbo yes but I was under the impression turbos were a bit lower then that.m
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
21.8:1 If I remember rightly from the spec sheet I had years ago.citroenxm wrote:Im sure xud 9te units are not as high as 23:1 .. n/a non turbo yes but I was under the impression turbos were a bit lower then that.m
I'd not use a standard gauge on a diesel engine. It'll simply blow it apart.
- CitroJim
- x 6182
- Contact:
Yep, that's quite correct Paul.citroenxm wrote:Im sure xud 9te units are not as high as 23:1 .. n/a non turbo yes but I was under the impression turbos were a bit lower then that.m
It's why generally a N/A diesel starts more easily and does not need quite so much pre or post-heating.
Turbo engines are around 18:1 from memory. Petrol turbos also have a much lower compression ratio...
The cams are a bit less agressive too.
If a TD had the same cam timing and CR as an NA engine it would not take the boost for very long without potential for detonation damage and high rates of wear. Same as for a petrol turbo really...
EDIT as Mike says.
