Reading back over this thread, because I have a similar problem following my minor accident in the C5. The pretensioners fired. I've replaced them with un-fired ones from a breaker, been in with Lexia and reset the ECU (cleared the fault codes) but the fault keeps re-appearing every time after re-starting the ignition.
I've even been into the airbag ECU settings, configured it for no pretensioners (just to see how it would behave) and it still comes back with the fault
I will try the resistor test today, but I wonder if the ECU is a 'one shot deal' (i.e. that it's hard written once the airbags or pretensioners have been deployed). Bloody annoying if so
Thinking ahead for removing one from a breaker/changing mine... It says above that you can see the plug/wiring by just moving the gear shift linkages aside, but does that mean you remove the ECU without taking the centre of the dash and gearshift out completely, or is that necessary?
EDIT:
Tested with resistors (see here in the car's profile thread) and no joy.
Any help with removal of the airbag ECU (as above) much appreciated thanks.
Pretensioner woes
- My Cars: Two C5's...
Lots of CXs...
A couple of Xantia...
A C2...
Lots of Prelude's...
And a Sunny! - x 66
- Contact:
Re: Pretensioner woes
Iain
1x '85 CX GTi Turbo s1 (metallic blue)
2x '85 CX GTi Turbo s2 t1 (metallic silver & grey)
'88 CX GTi Turbo s2 T2 (metallic light blue)
CX DTR T2 Safari (silver)
2x '96 Xantia Activa (Black & metallic green)
Iain
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3008
I will NOT swear to this, but I think I saw on this forum somewhere that somebody was able to send off their airbag ECU to get reset back to normal function. I think (but I am NOT certain) it was DHallworth and a C6 that had had its airbags fire when it had clipped a kerb. I hope that I am right.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
The easiest and cheapest option is probably a used airbag ECU module. Match the numbers and the brand on the labels on the top of your old ECU. There will be no programming involved, simply plug and play. Search on eBay.
There are also several outfits who can reset the crash data on your existing ECU.
- qprdude
- My Cars: Renault 5 TS, Renault 14ts, Citroen C5 Mk1, Renault Clio sport, Renault Laguna Privilege. Citroen C5 X7 Exclusive. Citroen DS5 D/sport . And around 25+ other brands from Morris Oxford to S Type jag and most things between.
- x 10
jgra1 wrote:yes, a useful tool aj, although there are a few of us around that have them..
I am not too far away from Guildford.. (About 35mins)
I think AJ's postcode is Gloucestershire. Guildford is GU
John
Rick.
2013 Citroen DS 5 D/Sport
- My Cars: 2006 C5 2.0 Litre HDI VTR Automatic Estate.(now sold on)
Currently Renault Zoe 2014 ZE - x 2520
That GL15 post code is the same as mine must be pretty close to me. Mine is GL15 6LEqprdude wrote:jgra1 wrote:yes, a useful tool aj, although there are a few of us around that have them..
John
Man is, by nature, a lazy beast, he does not need twice encouraging to do nothing.
- Donor 2023
- x 3008
I have done some checking, and it turns out my memory was correct. David Hallworth did get a C6 which had had its airbags trigger, and sent the airbag ECU off to get it sorted. Check from page 68 of the following link;
http://www.frenchcarforum.co.uk/forum/v ... start=1005
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Lots of CXs...
A C2...
And a Sunny! - x 66
- Contact:
Thanks, good to know I expect I can pick up an ecu from my local breakers for £15-£20 at the weekend. I'll ask David what he had to pay to get his cleared and see which works out the best.
Iain
Iain
