Malc or Handyman question, possibly
addo
Sara Watson's Stalker
x 95
Unread post by addo »
When repairing an inner wing in the UK, are you allowed by insurers to "short cut" it?
I mean, butt weld a forward section rather than go back to wherever the spots are (presuming the spotwelds are not that close)? That is assuming it's not a high strength alloy pressing, of course. Like, on a Xantia, if you cut the inner wing vertically in line with the rear of the battery tray, and butt-welded in a new or donor pressing. I refer only to the inner wing panel itself, not adjacent pressings like the forward wheelwell or strut tower, or any collapsible bracing.
x 94
Re: Malc or Handyman question, possibly
Unread post by citronut »
looking on service citroen
it shows the top/horizontal section of the inner wing from the head lamp mout/slam panel to the front of the strut turret, OE part No.'s 7119G3 and 7120K5,
to be a separate panel section from the main inner wing vertical section,
i think UK insurance companies would frown on cut and shutting section though, unless the were sections produced as a repair part
Regards, malcolm.
addo
x 95
That was my gut feeling, good to have local input though.
addo
x 95
Interesting conclusion to this one.
I consulted the Thatcham's guide for the car in question, and it condones a shortcutting repair, very clearly describing a MIG constant seam weld to join a repair section cut from the factory serviced larger panel. For this situation, it saves a whole lot of grief including dash and outer A pillar removal. From experience the repairers and assessors here will defer to Thatchams when you argue the toss, as the Methods (now e-Scribe) are used for a lot of Euro sourced vehicles.
Commonsense - who'da thunk it? :roll:
