Before this current flooding episode the inside of the car was damp for probably a couple of years unfortunately as it rarely got driven and had both a minor heater matrix leak and a minor rain water leak which was never found - but in retrospect I suspect the original rain water leak was simply the putty blob not doing its job correctly!CitroJim wrote: 07 Feb 2023, 18:57Mandrake wrote: 07 Feb 2023, 16:19 One thing the water has damaged even though it hasn't damaged the floor - is the headlining.![]()
That surprises me Simon as the headlining is quite a sturdy item and I always believed pretty much impervious to water with the top layer being impermeable. I've seen water from leaky sunroofs pour onto the top and run across the top without soaking through which can be very confusing as the water exits a way away from where the leak might have originated
I guess if the lining is wet for long enough then delamination, damage and a breach of the impervious layer will occur. How long do you think it was wet with condensation above it?
The fabric started to fall in a few patches about a year ago when it was sweated up over the previous winter, then this winter it has completely fallen - the fabric looks fine but it simply doesn't "stick" to whatever is above it now, if you press it up it hangs for a second and falls back down again.
I'm not sure what you mean by delaminated - the bit that is hanging down is the very thin final layer of fabric - it just doesn't seem to stick to the layer above it anymore. It seems like if you could remove that layer and spray down a VERY thin coat of spray glue and gently push it back into place it would stay there, but that's likely to be a nightmare of creases and misalignment.I'd be tempted to remove it completely - a surprisingly easy task - and then see about doing some repairs to it... PVA glue might fix any areas that have delaminated and a mild detergent ought to remove any straining...
You might need to do some strengthening work with contact adhesive and strips of heavy fabric to allow it to regain and hold its original form and shape...
Is there any trick to removing the headliner ? One problem I have is I don't really have a large, dry clear working area for the entire roof headliner to sit while out of the car so it's likely to get damaged.
