white exec wrote: 15 Dec 2018, 10:08 Breathe, usually, so any condensation has a chance to escape - usually through a small vent on the rear side, or even just through the bulb-holder flange itself. Regular headlight use keeps things dry as a rule.
The glass front has a neoprene gasket under it, all held down with the clips. This gasket can fail to do its job, sometimes as a result of re-fitting. It gets a bit delicate with age.
So removing, cleaning and refitting the gasket is probably a good idea then ? Is there any sealant that could be used such as a very thin smear of silicone grease ? I assume it would require the entire headlight to be removed to remove and refit the glass.
I think I've had a Xantia headlight assembly out once - over 10 years ago...but can't remember any details. Any tips ? Is it possible to get it out and refit it without disturbing the beam adjustment or is it pretty much mandatory that it will need adjustment again ? I don't have any level ground at home suitable for trying to look at headlight patterns so I'm reluctant to remove the entire headlight assembly if it means I need to get someone to readjust the beam alignment, on the other hand I would like to get the condensation fixed!
