Zel, that's generally my experience...
Gibbo2286 wrote: 05 Feb 2018, 13:50
Ah! but think about it Jim, you pop the cover off and staring you in the face is a blown resistor or a puffed up capacitor, you'd have a go wouldn't you.
The problem there is knowing what caused those components to fail...
In big SMPS/inverter type systems and the like the obvious failures are likely to be the symptom and not the root cause...
In the early days of SMPS being fitted to TVs and some professional gear, a critical part of the service information was what else to replace in addition to the obviously failed components to ensure they did not fail again...
The list was often extensive and could end up being expensive...
Also, some components in such a system need to be replaced with identical/approved components to maintain integrity and electrical safety...
You might successfully fix it using non-approved spares and then in an accident - even if not directly caused by what you did - might affect insurance...
Mandrake wrote: 05 Feb 2018, 14:02
Having repaired many [computer PSUs] and seeing how awful they are I'm actually amazed that some PC power supplies make it out of the factory still working let alone past the warranty period!
Same here Simon and that goes for high-end server PSUs too, not just ordinary PCs... Gosh, I've seen some of those server PSUs go off spectacularly with big flames shooting out of them
The general build and component quality is rubbish...
Good job the servers in question had multiple redundant PSUs!
I've also seen some brilliant fireworks from high power UPSs too - and those are closer perhaps to an automotive inverter than a PSU...
Having said that, if the car was free, or nearly so, there's be not much lost to have a go but I'd exercise great caution given the volts and amps involved and have a good fire extinguisher handy!
