You can tell if the turbo is working properly on 110s..
while the engine is idleing.. reach to the throttle under the lhm tank/air intake and rev the engine. . Watch the intercooler pipe at the front between the radiator and engine the turbo should spool up instantly and the pipe should expand under turbo pressure.. however if the wastegate is stuck open the engine will pull the pipe inwards. Both instances are quite noticable..
xantia exc 99 t reg hdi 110 turbo problems
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Re: xantia exc 99 t reg hdi 110 turbo problems
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
