URGENT URGENT HELP NEEDED C8 2.2HDI
'13 3008 1.6 HDi GripControl - x 1003
Re: URGENT URGENT HELP NEEDED C8 2.2HDI
There shouldn't be any need to bleed at the injectors - the pump just fills the rail, then when pressure is reached, injection should begin. It might be that you haven't get enough diesel up to the pump, but if you just keep pumping the primer, that should rectify itself. If you could talk to the ECU you could see what the injection pressure is doing, but as you can't.... I pretty sure that's where you troubles lie, but I can't really think how you can resolve
he is probably used to FIX OR REPAIR DAILY'S, or POXHALLS, as these always used to require the filter to be filled with fuel before and on fitting a new one,C8Charlie wrote:Hi Citronut!
No harm in pleasing simple minds sometimes, even when they are wrong!
Thanks again!
and sometimes cracking off the ujector pipes
HDI's have an electric lift pump in the tank that fills the system dont they?????
Regards, malcolm.
That only really applies to the 2.0 8V Mike, most, if not all, of the later ones have done away with the lift pump. The 1.6 certainly does without, and pretty sure the 2.0 16V (which has an HP pump driven direct of the other end of the cam shaft) does without.
- DickieG
- Monaco's youngest playboy
- x 38
My 2.2 C5 doesn't have a lift pump, I changed the fuel filter a couple of weeks ago and needed to squeeze the primer bulb to fill the filter.
13 Ram 1500 Hemi
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
