Ok, so when you go back into the ECUs present, has the status (Present / Absent) changed to the new values that you just configured, or have they gone back to the old values?
You might need to try this the way I listed it - from within the BSI, by selecting that and following my list.
C5 X7 2-in-1 navigation tutorial
- x 2338
Re: C5 X7 2-in-1 navigation tutorial
These are still changed. Like I did...
- x 2338
Changing some of the parameters, is not the same as deleting the ECU from the list, so try it the way I have shown you, just to see if this makes a difference.
- x 2338
Then after this, try a full BSI reset and leave extra time to allow the ECUs on the networks plenty of time to sleep and wake up.
Ok, I will try again exactly in the same way as you said, but more probably tomorrow, now it’s already dark outside... Regarding the BSI reset, how can I do this? Thank you!
- x 2338
It can help cure some electrical issues and should always be followed when disconnecting and re-connecting the battery.
Follow it exactly - it is important not to open the doors or press anything during the timings or the whole procedure will fail:
Battery Disconnect / Reconnect Procedure
Hello colleagues. There is a RT5 navigation on a forum of us at 550 E, if someone is interested. I remember that ECD5 has asked for a RT5 or?
http://www.peugeotclubromania.ro/forum/ ... D-550-euro
- Donor 2020
- x 104
Thanks Vlad!
Although it looks very pricey to me
You're welcome. Perhaps you can find more products there, I think they have these from some dismounted cars.
@Marc, sorry, I couldn't record the menu for synchronizing yet, I was very busy at the office...
Hi I wonder if someone can help. I replaced my rneg 3 head unit which died with an rneg 12 unit. Got most things work except... On the new unit there is no central dial. I can't select options on menus. I've tried with the right hand scroll wheel on steering column but that doesn't respond. I have access to lexia.
- x 2338
No such thing as RNEG 3 & 12...
Without properly understanding what original AND replacement Head Units you are referring to I can't help. What is your VIN so I can determine what you had and we can go from there. Coding everything and checking compatibility is essential.
Thanks for the reply. My vin is VF7**************[VIN obfuscated, can be read by forum staff]. It might be of help if I could send photos of the units to give you a clearer idea of what I'm on about.
GiveMeABreak wrote: ↑09 Nov 2017, 15:02No such thing as RNEG 3 & 12...
Top and bottom pic are from the original head unit. The middle pic is the replacement.
- x 2338
Ok, can you show me the front of the new unit please? I suspect you are trying to replace an RNEG (MyWay) with and RT6 (eMyWay or RNEG2) system. This will help confirm.
