Maybe a French vehicle would have been pounced on as a sure sign of corporation bias!
If looking for a replacement for the horsebox, maybe they need to be quick about it: might not be long now until the next chunk of *l*ct**n coverage
Thanks for the lead Jim! I do enjoy a bit of a delve.
I am afraid I have developed a bit of an unhealthy habit of looking up the DVLA MOT History check, at the least provocation. Its not as if I am a prospective purchaser, where such noseyness would be warranted. Now that particular van sailed through its last few tests, but had this rather long list to sort out a few years ago.
Regards NeilReason(s) for failure
Nearside Stop lamp not working (1.2.1b), Offside Stop lamp not working (1.2.1b)
Offside Rear Direction indicators not working (1.4.A.2c)
Nearside Headlamp not in good working order adversely affecting beam image (1.2.4a)
Offside Headlamp not in good working order adversely affecting beam image (1.2.4a)
Nearside Statutory seat belt missing (5.1.1), Offside Statutory seat belt missing (5.1.1)
Nearside Windscreen washer provides insufficient washer liquid (8.2.3)
Offside Windscreen washer provides insufficient washer liquid (8.2.3)
Front passenger door cannot be opened from inside the vehicle (6.2.B.1b)
Front passenger door cannot be opened from outside the vehicle (6.2.B.1b)
Nearside Windscreen wiper does not clear the windscreen effectively (8.2.2)
Offside Windscreen wiper does not clear the windscreen effectively (8.2.2)
Nearside Front Tyre has a cut in excess of the requirements deep enough to reach the ply or cords (4.1.D.1a)
Offside Front Tyre has a cut in excess of the requirements deep enough to reach the ply or cords (4.1.D.1a)
Offside Front Mechanical brake component has restricted free movement (3.5.1k)
Nearside Rear Trailing arm has excessive play in a pin/bush (2.4.G.2)
Nearside Front Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
Offside Front Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
Nearside Rear Vehicle structure is damaged, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
Offside Rear Vehicle structure is damaged, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
Advisory notice item(s)
Both front brake hose retaining clips broken, Excessive corrosion on fuel tank retainer.
NewcastleFalcon wrote: ↑11 Aug 2017, 20:10Excellent, and Robyn has captured that vital bit of info-the Registration number.
