Mk1 Xantia Issues
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 70
Re: Mk1 Xantia Issues
Yea James, they are. However, they should be an interchangeable thing the steering colums as the UJ ends where the colum attach's to the lower rod is the same size.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- Xaccers
- x 184
Long T30 at that and plenty of Percy wotsit to mate up as sometimes they can be a pita.citroenxm wrote:NO you WONT need a Torx 50 bit. you will need a T30 to get the air bag off, and a 22mm Socket to get the wheel off!!
Oh and when you undo the but don't do it all the way before pulling the wheel off, otherwise you could smack yourself in the face with it
DIY sphere tool
DIY sphere tool
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 2993
When we did Northern_Mikes' V6 he needed a T50 to get the wheel off to replace the slip ring.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- Xaccers
- x 184
His V6 was a S2 though wasn't it?Hell Razor5543 wrote:When we did Northern_Mikes' V6 he needed a T50 to get the wheel off to replace the slip ring.
DIY sphere tool
DIY sphere tool
YUP!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- Donor 2023
- x 2993
^Snap!
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- Old-Guy
- My Cars: 2011 Grand C4 Picasso VTR+ 1.6HDi in Kyanos Blue
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - now owned by XanTom
1998 Xantia 2.1 VXD Estate in Mauritius Blue - R.I.P. (terminal tin-worm) - x 17
Definitely a long thin T30 screwdriver for an S1; a ¼" hex drive T30 bit in a long adaptor is NBG as the head is down a hole too narrow for a ¼" adaptor.
Before starting disconnect the battery!
After removing both T30s centre the steering wheel. Unplug the airbag with your face outside the car!
Undo the nut and BEFORE disturbing the steering wheel, carefully mark the position of the wheel hub in relation to the shaft. Put the nut back, spin it down and then back it off ONE turn before attempting to loosen the wheel - otherwise you will smack yourself in the face with it.
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - after 11 years now owned by XanTom
If you grap the wheel 6 o clock IE: Top and Bottom and push top, pull bottom, and pull top and pull bottom in a rocking action while applying SMALL pulling action the wheel shouldn;t then POP you in the face, but wiggle loose, you can then draw it carefully, and not destroy the slip ring when the cable doesnt slide through as you smak your face!
NO Ive never hit myself, as Ive always used the above method...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- CitroJim
- x 6163
- Contact:
I have. Once. You only do it once and then learn from itcitroenxm wrote: NO Ive never hit myself, as Ive always used the above method...
Just a quick update - aux belt was fairly manky and a new one has sorted most of the noise. Don't fancy having to change the auto-tensioner, so its as good as its going to get. It also seems to have resulted in my brakes being significantly less terrifying, although they're still not completely right so a new accumulator and a bleed are on the cards for when money, time and good weather intersect.
Fuel gauge appears to have woken up with a bit of use, although it still only works when it feels like it so will try and get the correct bit off Old-Guy's breaker. Unfortunately I'm also having what seems to be fairly typical heater problems, although this did give me an enormous sense of well-being this morning when for a 15 minute period the fan and fuel gauge both worked at the same time...
- Location: London near that big building with the flashing light!
- My Cars: 2001 Xsara Picasso 2.0 HDi
- x 8
The trouble with the Aux belt is if the auto tensioner is cacked which they are more times than not as that's why belt goes mostly it won't tension belt properly.
the bearing which is needle rollers that don't move anywhere much so grind a slot in sleeve to run against and being where it is get's hot then cold and Citroen show it the grease pot then quickly take it away so never gets much from new.
also theres a shock absorber type item that bolts to cradle and other end on side of tensioner that gets shagged out also with rubber bushes getting elongated.
Citro Jim's the boy for info on that job and Old-guy's probably got some serviceable bits from his one.
As been said if belt fails they like to take out as much bit's as it can normally your timing belt.
So if you do get red light come on don't try restarting it have a head under bonnet look.
If you do have to replace tensioner take new one apart and give it a good splodge of grease.
It's not that hard a job just getting bearing sleeve out of cradle is the hard bit a 1/4 drive socket extension bar fits in eccentric pulley
The newer tensioners use around an 11mm square where as older used 3/8th if i remember right?
but someone clever will be along soon!
