Reluctor ring
Re: Reluctor ring
Thanks Richard, I saw that bolt but ruled it out. That looks simple enough. Hell Razor - thanks for your advice. I already have the wheel and hub off so can easily get to fill point.
Citroen Dispatch 1.9D 2005
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3008
Re: Reluctor ring
I am assuming that the gearbox will be like the BE3, so the layout would be similar. You can get the oil from Citroen, and it cost me about £15 for 2l. You MUST get the right oil, as anything else is likely to damage the gearbox.
I found it easier to fill the gearbox through the reverse switch hole, as I didn't have anything that could get the oil through the 'regular' filling point without spilling a load on the ground.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Re: Reluctor ring
Thanks Richard. I had seen that bolt ruled it out. I have some 75-80. Hell Razor - thanks for the advice - I already have the hub off - so it is very easy to access. Best wishes Shane
