1.6 HDI oil pick up issues
My Cars: 2006 C5 2.0 Litre HDI VTR Automatic Estate.(now sold on)
Currently Renault Zoe 2014 ZE
x 2521
Re: 1.6 HDI oil pick up issues
Post by Gibbo2286 »
Stickyfinger wrote:From what I understand, it is carbonized diesel/oil mix. A chemical engineer (Classic Jag racer) once explained to me that with older mineral oils, the carbon particular formation was like a snow ball, round and layered. With Synthetic oils in the mix, it forms in a laminar shard-like form, this is harder to flush as it locks together. He exclusively only used Castor or 100% mineral dependent on the race......
Are you sure it's not debris from the broken turbo, it was on my 2004 2.0 HDI, my oil pick up was just like the one pictured, unfortunately after cleaning it all out, flushing the system and changing the filters it ran fine for a few weeks then threw up a low oil pressure warning and started to knock, I suspect there's a blockage in the oil galleries.
It's now been sitting on my yard since before Christmas waiting for me to make my mind up what to do next. (See my post 'Offers invited' in the for sale and wanted forum.)
Man is, by nature, a lazy beast, he does not need twice encouraging to do nothing.
My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars.
x 1207
Post by Peter.N. »
It does actually state in the C5 Haynes manual that the oil in the diesels should be changed every 6000 miles, it also states "Frequent oil changes are the most important preventative maintenance the DIY home mechanic can give the engine ..."
I am wholeheartedly in agreement with that. Surely whatever it is that is contaminating the oil won't cause as many problems if its frequently removed, if I had a 1.6 Hdi I would certainly be changing the oil every 6000 miles or even 5000 given their history, its a lot cheaper than a new turbo.
I only change the oil in my 2.0. 8 valves every 8000 miles because they are a very clean burning engine and have a larger sump capacity than the 1.6, the oil at 8000 miles is no dirtier than at 5000 in the XUD engine.
Donor 2023
My Cars: C5 Mk2 VTX+ estate.
x 3008
Post by Hell Razor5543 »
When my company van is serviced the mechanic jacks up the nearside by quite a way to help get as much oil out as possible. Fortunately my van is one where they had recognised the problem, and had fitted the newer banjo bolt with the long filter (amongst other things).
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally
x 1300
Contact:
Post by Stickyfinger »
In this case I would agree, they be shiny bits . I was talking about the carbon contamination of the oil which is the reason (it seems) that the turbo and other oil feeds and pick-ups/filter get blocked giving the above result.
Activa, the Moose Rider
3x C5x7 Steering racks and counting
uncle buck
My Cars:
x 5
Post by uncle buck »
I've been around and worked on various diesel engines in cars, vans & trucks over the years and not one of them has dirtied the oil as fast as the 1.6HDI following an oil and filter change.
We all know that the oil in a diesel engine doesn't stay clean as long as in a petrol engine but with this engine it's as black as the old oil within a couple of days.
You can never remove all of the old oil from any engine, there will always be a little remaining but this engine design takes it to a whole new level, with reports of around 500 ml of old oil remaining within the engine in various locations but mainly the sump with its inward recessed drain plug :shock:
Cheers.
2006 C4 1.6 HDi 16V (92) non FAP
2001 Xsara II 1.4 LX
2001 Renault Laguna II 1.9dCi Sport Tourer
Lighty
My Cars:
x 34
Contact:
Post by Lighty »
Blimey, not been here for a day or two, and loads of questions.
No idea what causes it tbh, I have a feeling that DPF is high on the list, and injector seals. Next is EGR,& then low oil capacity.
The Citroen dispatch van has a sump sandwich plate that increases capacity, and these seem to be more reliable.
Basically if you change the oil every 6 k , and don't sit for hours in traffic! and don't do loads of short trips where the engine never gets properly hot! you will be ok. If some or all of the above apply, buy a petrol.
P.s it was a 110 bhp C4 Picasso.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
citroenxm
My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising
x 71
Post by citroenxm »
uncle buck wrote:I've been around and worked on various diesel engines in cars, vans & trucks over the years and not one of them has dirtied the oil as fast as the 1.6HDI following an oil and filter change.
Cheers.
Uncle Buck, I can tell you WHY 1.6 engines in 16v form dirty their oil straight after an oil change..
Because of TWO Stupid design ideas!! Firstly the first one is solvable by which I beleve a replacment sump is avaliable with inverted DOWNWARD drain plug! The original in indented upwards into the sump this allowing about a quarter of old oil to remain in the sump after a drain! It cant go uphill! :-D :wink:
Secondly, the 16v head design internally under the rocker fingers is such that another almost half litre remains in two large areas above cylinder 1 and 4 in the head, which ALSO does not drain away after a change!!
8v engines drain far easier, as theres less internal area for the oil to sit, and in the case of the 8v HDi 2.0 engine the sump plug is on a bottom edge, so effecivily ALL oil can be drained from these older better engines.
So, this I find is WHY the oil blackens so soon after a change, theres too much old oil still IN the engine after a drain.
A very sad...
1994 XM 2.1 d auto
citroenxm
x 71
Post by citroenxm »
Lighty wrote:Blimey, not been here for a day or two, and loads of questions.
DPF wont help, but I think ultimatly from reading around its injector clamp bolts therefore seals that cause it all..
Think about this: PSA DO NOT advise checking the injector clamp bolt tightness's at service.. do a search, see how many failed engines you will find.
Slightly less so with Ford in the fiesta and Focus.
HOWEVER, volvo also use this engine in the V/C 40's etc. Now, Volvo DO reccomend a tightness check at service in the clamps, now, do a search for Volvo 1.6 diesels, and see how many failed engines you find in them... last time I looked ZERO! None.
That to me explains a few things, I think. And yes - it IS the same engine..
A very sad...
1994 XM 2.1 d auto
addo
Sara Watson's Stalker
Location: NEW South Wales, Australia. I'll show you "Far, far away" ;-)
My Cars: Peugeot 605
Citroën Berlingo
Alfa 147
x 93
Post by addo »
I believe the oil is "damaged" in the head by high temperatures. DPF and leaky injectors being high on the suspect list.
uncle buck
My Cars:
x 5
citroenxm wrote:Uncle Buck, I can tell you WHY 1.6 engines in 16v form dirty their oil straight after an oil change..
yeah we've had this conversation before, I also noticed the area in the head that holds the oil .
I'm interested in the replacement sump....you got any details?
Cheers.
citroenxm
x 71
Post by citroenxm »
No I have not actually, I think RichardW might of fitted one, and know about it..
A very sad...
1994 XM 2.1 d auto
My Cars: MK2 '17 C4GP 1.6 BlueHDi 120
'13 3008 1.6 HDi GripControl
x 1003
Post by RichardW »
Not I - I just refitted the old one, complete with up turned plug. Someone else beat the plug on theirs out flat - there's some pics somewhere.
uncle buck
My Cars:
x 5
I know Axa pressed the sump recess out so it was outward facing instead of inward.
I spotted a new sump on ebay that has the recess facing outwards and what appears to be a larger size drain plug, the seller has it listed to fit a Berlingo 1.6 HDI or other HDI's.
http://www.ebay.co.uk/itm/citroen-berli ... _95wt_1181" onclick="window.open(this.href);return false;
I'm wondering where it came from, as looking on citroen service the Berlingo sump is the same sump as listed for any of the 1.6 HDI's with the recess facing inwards....so I'm guessing it's an aftermarkt item?
Cheers.
Axa
My Cars: 2008 Renault Grand Espace 2.0dci Auto.
2006 Citroën C5 1.6hdi.
Post by Axa »
After pressing out the recess around the plug, I can now fill 4litres instead of around 3,75.
I also overfill the engine 0,1-0,2L without any problem so far. I've heard there is a replacement oil dipstick with higher marks. Do anyone know more about that?
2006 C5 1.6 HDi ( vin: VF7**************[VIN obfuscated, can be read by forum staff] )
2008 Grand Espace 2.0Dci Auto
Post Reply
