LED Tail Light Upgrade
Re: LED Tail Light Upgrade
The resistors are on the pcb inside the lamp, you have to force it apart (be gentle) and you may find they have rusted out, mine had and also the tracks on the pcb were damaged by water ingress....hope this helpsnnvi86 wrote:I dont have any resistor as far as i know?
l love Citroens
2001 C5 2.2hdi sx Estate
2008 C5 2lt hdi Tourer (estate)
- My Cars: Now:
C5 X7 HDi 240 Exclusive Tourer
ZOE 22kwh Intense
Before:
C4 1,6 Coupe Automatic
C5 X7 HDi136 Exclusive Sedan A
Xantia HDi110 Berline
Xantia 1,8SX Berline - x 28
Do these led-indicator -bulbs work with standard indicator relay? And is it possible to change indicator relay on C5 MK3?
Will let you know soon
Not sure what wire i should install the resistors on the indicator ? Imahe below
http://lfamedia.com/c5-ind.jpg" onclick="window.open(this.href);return false;
and the resistor for the break light, what wire do i install the resistor?
http://lfamedia.com/c5-break.jpg" onclick="window.open(this.href);return false;
check out the video
check out the video
- Location: London near that big building with the flashing light!
- My Cars: 2001 Xsara Picasso 2.0 HDi
- x 8
Heres Canbus for you explained. http://www.car4play.com/forum/post/index.htm?t=9436" onclick="window.open(this.href);return false;
- x 8
What in effect happens is that when you turn something on it sends a pulse to module which then in turn sees a load now if that load isn't there or diminished it registers a fault as the load keeps module active until turned off.
the joys of modern cars it came about to use less wiring as lighter load fed through switches many pre canbus used a switched return power went to relay and say headlight switch grounded out relay so only a light load going across and main current was from battery to light.
where as old cars70's and before the power went to the actual switch so A was more of a fire risk B took alot heavier wiring.
If you check out LED listings they spec canbus types or non.let me see what ive got in my bookmarks?
http://www.skeenway.com/auto-led-bulbs/ ... light.html" onclick="window.open(this.href);return false;
http://www.candlepowerforums.com/vb/sho ... tions-quot" onclick="window.open(this.href);return false;
http://www.led-nova.com/canbus-error-free-bulbs.html" onclick="window.open(this.href);return false;
Hope that helps!
The benefit of leds far out weigh the little problems at first as ive all leds great not havinbg to worry about tail light out etc if good ones. as some a bit crap in the stop n tail type with how they have made them.
Plus great on trucks now as no longer have trailer lights blowing every time running with an empty 40ft box as bangs on chassis and as you come of brake filament is hot still and pops or a ham fisted docker dumps it on trailer so shakes everything including driver so halve the bulbs go.
Hope that helps!
