Well the Guy came yesterday and connected me to the Lexia, well not me but the car, and found no end of faults, cleared most of them and then had the pump running and the car going up and down, brill l thought problem solved, Nooooo, when we tried to raise the car with the ride height adjustment in side or in the boot, nothing at all it just would not work, he tried several times but no. and then he found it ......bad connection on the rear ride height sensor on the rear, just touched it and away it went, he did find a couple of other small faults and she’s running fine now.
Thanks for all your help with this….regards Pete
c5 suspention serious fault
Re: c5 suspention serious fault
l love Citroens
2001 C5 2.2hdi sx Estate
2008 C5 2lt hdi Tourer (estate)
Hi,don't know if this helps.
I had a problem with my 2.0 HDi 2001 estate, where my rear suspension went to the absolute top with the warning serious suspension fault consult your dealer. The ride was so hard it rattled my fillings, I found the problem to be a dog bone type link on the rear suspension (actuator I think it is called) replaced from local Citroen dealership £7.00 result.
