Does this help?
http://www.renault4.co.uk/tech-brake-drums.htm" onclick="window.open(this.href);return false;
I have a Xantia S2 V6
- Donor 2021
- x 1656
Re: I have a Xantia S2 V6
No, sadly not, as mine are sweet FA like that. They might be off a Renault 6... welcome to kit-car hell... they might be off an early 5.
- x 553
Bleeding: Gunson's eazi bleed - piece of cake then! Don't try it until you have the drum and shoes on - unless you clamp the cylinder so it doesn't just pop out
Reuilding: Take a photo before removing (oops!); copy the other side. Are they auto adjusting? Should just fit up, adjust it so that the drum just slips on, bleed the brakes, then stamp on the pedal a few times which should then take up the slack in the adjuster. Shouldn't be any need to re-bleed.
- Sara Watson's Stalker
- x 5
