Berlingo battles and DRKpers
addo
Sara Watson's Stalker
x 94
Unread post by addo »
I think the M49/59 Berlingo is simply a great design. Load space, plus a fun drive.
Northern_Mike
I thought that myself earlier today Addo. The recycling centre shuts at 8pm and I had 20 mins to get there down back roads loaded up. I fairly charged along, hit pretty naughty speeds a few times, hurled it into bends and it is a lot of fun. Does need new front tyres though now..
Think I might keep it now if the MOT isn't too bad.
Sent from my SM-N9005 using Tapatalk
x 6828
Re:
addo wrote:I think the M49/59 Berlingo is simply a great design. Load space, plus a fun drive.
Indeed, one of the all-time classics. I'd definitely keep it Mike :)
Donor 2023
x 3086
Re: Berlingo battles and DRKpers
Mike, if you can let me know what the nipple end of the cable looks like (with a photo) I will nip into a bike shop and see if I can get a replacement cable.
Northern_Mike
Hell Razor5543 wrote:Mike, if you can let me know what the nipple end of the cable looks like (with a photo) I will nip into a bike shop and see if I can get a replacement cable.
You can take the whole cable James, I'll remove it later this evening and meet you somewhere with it if you like. It needs a custom nipple on one end - lots of places seem to use them. I was going to send it away to a bespoke cable maker but you can have a go first if you wish..
Donor 2023
x 3086
Re:
northern_mike wrote:I thought that myself earlier today Addo. The recycling centre shuts at 8pm and I had 20 mins to get there down back roads loaded up. I fairly charged along, hit pretty naughty speeds a few times, hurled it into bends and it is a lot of fun. Does need new front tyres though now..
Twford to Smallmead in 20 minutes? Where did you get the flight conversion kit from?
If it's OK with you, I'll pop up this evening. Just let me know when I can collect it.
Northern_Mike
No, Longshot lane in Bracknell, but I can do Smallmead in 20 mins if you mean the one near the football stadium. That's easy going down through Hurst and along Lower Earley way..
Northern_Mike
Well, thanks to James "Alistair" Hellrazor, the DRK now has a new throttle cable fitted, that returns properly and makes the car a whole different beast to drive. Had a bit of fun fitting it - it's actually a bicycle cable which we "altered" and made to fit. The bike barrel nipple stayed on one end, we chopped the other off and used a screw-on item once we'd cut the cable to the right length and worked out how it all went together - mainly James' work as I was asleep on the sofa when he tapped on the door, and once I'm in position under the dash, I don't like to get out again.
Took it for a test drive just now, goes much better, so much easier to do gearchanges too as James spotted a knackered bushing in the gearchange assembly that I've glued back together.
Of course, under the dash, I knocked some electrics so now the lights only work when they want to.
Berlingo - well there's some scrap Partners and Berlingos in the local yard. I was going to take a wander down tomorrow, but I think I will do the brakes on the DRK instead while I'm in the mood and the family are out! I need to get the VINS off the scrap vans first, to see if the parts I want will be of any use to me at all before I go down there and take them off.
Donor 2023
x 3086
Those vans are at the far end of the yard, on the ground, so you will be able to get the VINs easily. That C5 I saw was in the Citroen section, one level up.
Just a thought. If you were to install those disks I gave you onto a laptop, and make a note of Berties' VIN, you could see if the parts match while you are there (and not risk somebody else snaffling them!). Just remember, if you decide to install disk 3 (with all the diagrams) it warns that it could take 300 minutes. I don't know haw long it took on my PC, as I let disk 3 get on with it when I was out.
x 6828
James, excellent work you've done there today for Mike :-D
Donor 2023
x 3086
Jim, it might (but probably isn't) worth letting Chris know there were also 3 RX8 at the same scrappy, but they didn't look like crash damage scrapped.
Northern_Mike
Today I battled for a few hours with the DRK brakes. New shoes fitted, but I have to try my one-man bleeding trick before I can test drive it. Pics to follow of brake issue..
Northern_Mike
Re: Re: Berlingo battles and DRKpers
Hell Razor5543 wrote:Jim, it might (but probably isn't) worth letting Chris know there were also 3 RX8 at the same scrappy, but they didn't look like crash damage scrapped.
The things never go far enough to crash..
x 6828
Good news on the DRK Brakes Mike.
I have one of those one-man bleeding kits and it works a treat... It's only a one-way valve in a bottle. Nothing special.
x 93
Unread post by citronut »
i have one of these
http://www.halfords.com/motoring/garage ... -eezibleed" onclick="window.open(this.href);return false;
Regards, malcolm.
