knocking in c5 engine.
Re: knocking in c5 engine.
I was thinking the same myself! I wasn't on the FCF back in 06 or 07 when the early Xantias would be the same age as the early C5s are now. I wonder if there were as many posts with weird problems? Were the BX crowd all saying the number of their posts were being overtaken by Xantia posts?
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX - x 4888
When I joined after buying my first C5 then C5 posts were quite a rarity.
There has been a fairly steady increase since then.
- falling-out-with-my-car
- My Cars: Citroen C5 Aircross 8 speed Automatic, Flair Model with far to many toys and nice comfy armchair like leather seats. ha ha Ive just had a conversation with the car. setting everything up verbally
- x 24
Injector knock goes away when the engine is warmed up My Xantia 1.9TD had stuck injectors and they knocked badly
when the engine was cold but as soon as it warmed up the knocking stopped completely, stuck injectors can also make the engine hard to start from cold to. my cam belt went two years before its time because the cam belt was over tightened and this destroyed the toothed crankshaft cambelt pulley behind the auxiliary belt pulley the damaged cambelt pulley cut through the belt and snapped the camshaft in half.
all fixed now though thanks to Xac and Jim on the forum, and Barry at Bourne Citroen.
Ok bump. Just taken to garage. Bloke in garage checked all the bits n bobs and nothing was loose.
And here's the sh1tter. He says the knocking (which is intermittent) is coming from inside the engine.
So just spent a couple of grand on another duff car????
C'est pas possible!
- My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1199
It sounded to me like a tensioner, could be on the cambelt or perhaps an idler, didn't sound very serious to me. Is it getting any worse?
Not any worse (the video I posted is not great as the sound aint obvious as it is in real life) but guy checked everything and yes it did seem to me first time to be inside engine but then again sound travels.
Wondered if it was the pistons hitting something.
Or timing out. Dunno I know nowt other than "here we go again"
C'est pas possible!
Sounds more like a rattle than a knock, do you have any forum members nearby that can have a listen to it for you. I will if you like but I'm rather a long way. Will be in Scotland in May if you haven't got it fixed by then
There are only a few things *inside* an engine that can rattle, and a decent mechanic should be able to recognise those. On the other hand, modern engines have a load of ancillary stuff, but most of that is get-at-able without too much trouble, so is less of a problem.
Thing is its not a rattle. Its a knock. More substantial.
C'est pas possible!
'13 3008 1.6 HDi GripControl - x 983
They were, so much so they buggered off to their own forum Maybe us Xatians will have to take the same route....Northern_Mike wrote:Were the BX crowd all saying the number of their posts were being overtaken by Xantia posts?
What I heard on the youtube clip was a rattle so I must have missed the proper noise.
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1280
- Contact:
its TIME for
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- Locked user account
- My Cars: A used Citroen
- x 27
@ sticky - I don't think anyone will want to put a broom through his head just to amplify the car noises ... ...
- Stickyfinger
AX, little Daffodil
- Contact:
would not do me any damage
And how would the broom help me. I know they amplify noise but would it indicate where it is?
Incidentally what with the xantia p1sstake?
C'est pas possible!
