picked up my Exclusive Estate 2 liter hdi
Re: picked up my Exclusive Estate 2 liter hdi
where's the ignition coil light on theses things. Do they have one
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 70
Direct injection Paul, No real need for heater plugs.. but if you REALLY want to find it, its in the same place as the TD, bolted to the inner wing beside the battery..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Oopps.. The light will RARELY come on, as the direct injection doesnt need heating...
It may litterally for a SPLIT SECOND flick on then off when you first turn the key on... but thats about it... the light is in the same place as the TD's
The HDi is a very different engine to the ole TD engine. Im YET to put a set of heaters in my HDi in over 100k miles...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
They do, but the HDi rarely uses the glow plugs as it doesn't need them unless it's very cold.jacksun1987 wrote:where's the ignition coil light on theses things. Do they have one
I've never seen the one on the Berlingo come on in 2 years. Lexia showed me that some of the plugs were duff in summer 2012, so we replaced them anyway.
Thats lucky its a 2 litre Mike. 1.6 16v HDi plugs dont come out, the heater element BREAKS off in the head! NEVER attempt to change plugs in the 1.6 ...Northern_Mike wrote:They do, but the HDi rarely uses the glow plugs as it doesn't need them unless it's very cold.jacksun1987 wrote:where's the ignition coil light on theses things. Do they have one
2.0 ones arent so bad..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
did notice thats its a lot better starting up then my old tds
If its a 110 working correctly it should ALSO go a damm sight better too, accelleration and speed!!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
yep it sure does. But i notice a slight noise. When im revving high. Like a rough sounds. But apart from that. Its a lot better
found out another grovy thing. I i put it in reverse the passenger side mirror comes down
And i can drive it with out no key Gd for defrosting the car. Had it on the black bx. Start it up take key out lock the doors.
Love to take it on a long run. See how it goes on fuel.
Oooerr that key thing is a BAD THING Paul.
you might find then that ANYTHING will turn the barrell, even a screw driver, that should NOT happen..
As for dipping mirror thats an Exclusive Spec item!!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
It won't start with a screwdriver will it, as the immobiliser tag won't be present... if so, I wouldn't worry about it too much. I wouldn't do it when driving though, just in case the steering lock suddenly activates!citroenxm wrote:Oooerr that key thing is a BAD THING Paul.
Good point mike.
Im half alseep here these days...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
It's the best way to be Paul. The only way, in fact. Apart from when you're driving , of course.citroenxm wrote:
just a quick one is this my paint code ERY "Vega Green" Ive got the dark green one
Yes Paul,
ERY is the paint code, on the Plate on the inside of the drivers door A pillar, when the door is open..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
