evening Chaps! have been busy batteling against the car past few days but am happy to report that its all back together now with New arm bushes ball joints and lower engine mount, just the exhaust sealing ring to go!
when working on it i noticed that the lower gearbox bolt had worked itself loose and come out, i'd hazzard a guess as to that being what clonked under the car on the way back when it started playing up?? Anyway, i have fashioned one up with some threaded rod and a couple of nuts, as i didnt have anything else that fitted,
Now, on putting everything back together and a short test ride around the block the vibration in 3rd/4th seems to have stopped, i am going to run it down the coast road over the next couple of days to check But! is it possible that the box had worked loose dropping the lower bolt being at an odd angle and thus causing the nasty vibration?? Or! is it that due to it being sat for a couple of weeks not used the bearings have stopped making noises??
i am kinda hoping that the first is the case and i dont need a replacement box,
Xantia clutch death???
- Timmo
- My Cars: 58 partner teepee outdoor hdi.
58 C2 Code in black! Fun! - x 168
- Contact:
Re: Xantia clutch death???
'58 C2 Code
'58 partner teepee outdoor
'58 C2 Code
- x 3
If the bottom bellhousing bolt has dropped out then that would perfectly explain the vibration, particularly if it was the back one. There are normally only 4 bolts holding the engine and box togetherand the bottom back one is the most important. Looks like you saved yourself a few ££s.
