Clutch Cable
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Re: Clutch Cable
If its the BLACK clip it wont be! They are ALL in "The Wrong Way", in which the head needs cutting off, old bolt sliding out, new clip fitting, a bole back in the other way, and the nut put on between the clutch and brake pedal...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- Donor 2023
- My Cars: 2013 Peugeot 3008 Allure 1.6HDi - FD63 FWA VF3**************[VIN obfuscated, can be read by forum staff]
1995 Citroen Xantia 1.9TD S1 - M728 GDL VF7**************[VIN obfuscated, can be read by forum staff]
1996 Citroen Xantia 1.9TD SX S1 - N707 MGP (Currrently laid up)
2000 Citroen Xantia 2.0 HDi S2 - X435 JGJ VF7**************[VIN obfuscated, can be read by forum staff] (Clutch died Dec 2017 - Resurrected Easter Sunday 2021)
1997 Citroen ZX SX TD - P788 AJL
1959 Landrover Defender S2 - Two owners from new
1968 Triumph Vitesse Convertible 2.0
1980 Ford Escort RS2000 Customer - 2nd Owner
1988 Saab 900 T16S - A 1980's exercise in understated Hooliganism...
Oh! and two Harley Davidsons - A 1990 Sportster and a 2003 Fatboy 100th Anniversary (the only vehicle I have owned from new) - x 80
Re: Clutch Cable
Guys.
It's all done.
Bolt was in the wrong way and it was on the original clip. B*st*rd of a job!
New cream slip was fitted this afternoon but I have fitted the metal clip on the wrong side according to the picture on service Citroen as link posted earlier by either RichardW or Hellrazor.
Not convinced that the metal clip could cause plastic cream slip to fail if fitted wrong way though but if it has to come off again, it simply has to come off again. I think on other link viewtopic.php?f=11&t=21201&p=295044 someone suggests that it is clearly touching when pedal is fully depressed!
It's all done.
- Donor 2023
Re: Clutch Cable
On the subject of clutch adjustment, is this measured to passenger side centre of the rubber pad?
And is it an absolute measurement in that? 155 from floor at right angles to centre face of pedal or is the depressed depth of approx. 20mm. deducted. Therefore, true measurement 175mm?
'13 3008 1.6 HDi GripControl - x 996
Re: Clutch Cable
It's pedal travel, so it doesn't matter where you measure it from - measure off the floor to the pedal face, then press it down and measure again. Difference = travel. You might be able to measure it off the steering wheel - not sure on the alignment. However, if it doesn't slip, and you can easily engage the gears, and the bite point is not right on the floor making driving difficult, then it will be OK!
- Donor 2023
Re: Clutch Cable
Cool. Thought I had interpreted it right. Anyway, in the end, I chose to go with 155 off carpet so approx. 135 travel and pedal is way above brake at that.
The metal clip is designed not to foul the clutch pedal but....
It is within a gnat's hair of touching the clip when fully depressed.
The reason my Citroen Indy neighbour says they generally go again is because the nipples chamfer slightly and force their way out of the clip not because of the clip orientation.
I hope it holds out. Not a job I want to repeat in a hurry. Touch wood!
