The suspension fluid is in the black plastic tank. I have had mine open several times with no adverse effects. (not with the pump running of course). If you open it, you must be sure to thoroughly clean around the cap first, and ensure that NO foreign bodies get into the tank.
Again, search the forum for topping up the fluid etc.
C5 Suspension
- qprdude
- My Cars: Renault 5 TS, Renault 14ts, Citroen C5 Mk1, Renault Clio sport, Renault Laguna Privilege. Citroen C5 X7 Exclusive. Citroen DS5 D/sport . And around 25+ other brands from Morris Oxford to S Type jag and most things between.
- x 10
Re: C5 Suspension
Rick.
2013 Citroen DS 5 D/Sport
- qprdude
- x 10
Re:
Does the X7 have a mechanical sensor?addo wrote:It's quite common for the rear sensor here to wear out; couldn't rule the front one out of contention on this basis.
Rick.
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX - x 4922
Re: C5 Suspension
Perhaps it was a consultant surgeon masquerading as a mechanicqprdude wrote:£95 an hour? Are you sure you're in Yorkshire and not Knightsbridge?
- qprdude
- x 10
Re: C5 Suspension
myglaren wrote:Perhaps it was a consultant surgeon masquerading as a mechanicqprdude wrote:£95 an hour? Are you sure you're in Yorkshire and not Knightsbridge?
Better that than the other way round Steve.
Rick.
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
Re: C5 Suspension
I believe that there are a few of those floating around too.
Re: C5 Suspension
If the X7 C5 is the same as the early ones then the front & rear sensors are the same, you could swap them round & see if the fault changes to the opposite axle.
