Merged Lexia & Diagbox threads
Locked
sonoramicommando
My Cars: 1991 Citroen XM 2.0 carb manual
x 5
Re: Merged Lexia & Diagbox threads
Post by sonoramicommando »
nope. couldn't install that - straight to install error.
took apart the VCI but everything looked ok.
i'm going to uninstall diagbox and go back to lexia only version + VCI (which I bought off Aliexpress a while ago). this worked back in C5 days, so no harm in trying.
2006 C6 Exclusive 2.7HDi
1982 GSA Pallas
A couple of bikes
A boyracer car ;)
sonoramicommando
x 5
ok the lexia install done - at least the lexia recognises both old and new interfaces.
will try on the car tomorrow - fingers crossed.
1982 GSA Pallas
A couple of bikes
A boyracer car ;)
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow
x 5708
Post by GiveMeABreak »
Ok good luck, maybe with less overheads the standalone version will work on yoour system.
My Cars: 2006 C5 2.0 Litre HDI VTR Automatic Estate.(now sold on)
Currently Renault Zoe 2014 ZE
x 2507
Post by Gibbo2286 »
I've bought one of those Bluetooth ones listed on easydiagnostics, I'll let you know how it goes when it arrives.
Man is, by nature, a lazy beast, he does not need twice encouraging to do nothing.
Barry52
My Cars: 2009 Citroen C4 Grand Picasso. 1.6
2001 Citroen Evasion/Synergie 2.0 HDI
Post by Barry52 »
Hi All
I wonder if anyone else has had this problem, I upgraded from Diagbox 7.02 to 7.57 but now when I connect to the car and start fault finding it tries to connect to PSA and the internet then when it can't it puts a big pop up on the screen trying to diagnose connection problem the problem is I can't see the screen behind to see if there are any faults !! Any ideas [-o<
C15 Romahome White
CX 20 Polar White
x 5708
Gibbo2286 wrote: 17 Mar 2018, 10:01 I've bought one of those Bluetooth ones listed on easydiagnostics, I'll let you know how it goes when it arrives.
That'll be interesting Gibbo- look forward to hearing about your experience with it.
C15 Romahome White
CX 20 Polar White
x 5708
Barry52 wrote: 17 Mar 2018, 10:14 Hi All
Hi - when using your Diagbox system, leave your wireless / network card enabled - but DISCONNECT from any active network connection (and don't allow it to reconnect) whilst using it. When it says 'Check for Updates' or anything press the Red Cross and it will carry on as normal. You should not have it connected to the Internet during use.
lancia58
(Donor 2022)
My Cars: Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
x 8
Citroen Doc Backup - message "Corvet@ not available"
Post by lancia58 »
When I try to get parts by VIN in the Citroen Doc Back Up I got the following message "Corvet@ not available". It means that it can not find car parts by VIN. A week ago I was able to get car's parts by VIN and since last week I got this message. I think it happened after I updated the Java. Any one knows how I can solve it.
Zohar
C15 Romahome White
CX 20 Polar White
x 5708
Access has been removed from off-line versions by PSA a few weeks ago, after the merging of the Marques.
sonoramicommando
x 5
What is Lexia equivalent of APPDIAG.SYS in Diagbox? Do I need to make a copy of the licence file (whatever that is)?
1982 GSA Pallas
A couple of bikes
A boyracer car ;)
C15 Romahome White
CX 20 Polar White
x 5708
We normally refer that as the licence file for Diagbox as Lexia and Peugeot Planet 2000 software is encapsulated within it. So just backup that APPDIAG.SYS file. If you are installing stand alone Lexia I don’t think it is applicable
sonoramicommando
x 5
still only recognises injection & suspension control units. so basically the same problem as I started off with.
i picked up an interface checker program from somewhere (I can't remember where and why) - will this able to tell me if the interface has a problem? if so, can anyone tell me how to use this thing?
cheers.
1982 GSA Pallas
A couple of bikes
A boyracer car ;)
lancia58
(Donor 2022)
x 8
Post by lancia58 »
Hi Marc
What is "Marques."
Zohar
C15 Romahome White
CX 20 Polar White
x 5708
Are you actually sure you have a full-chip kit? - not all the clones have all the board components to talk so some models of Peugeot and C5 / C6 - or is your unit an older revision B unit? - in which case it may only work with older versions of Diagbox (some will only work with DB 5/6, but others have reported success with DB V 7.02). There are no hard and fast rules here because of the clone market and they are not all made the same.
If you have the interface checker - connect up your VCI to your laptop via USB (not the car) and launch the interface checker programme, then hit the 'Version' button and 'Reference' buttons and post a screen shot so I can see it.
C15 Romahome White
CX 20 Polar White
x 5708
lancia58 wrote: 18 Mar 2018, 12:17 Hi Marc
What is "Marques."
Zohar
Hi Zohar, the 'Marques' are the collective PSA brands if you like - Citroen, Peugeot, DS Automobiles (and in Europe of course GM Vauxhall that PSA have recently bought).
Locked
