C5 MOT questions
My Cars:
x 92
Re: C5 MOT questions
Post by citronut »
jgra1 wrote:
Boots.. going to ignore them. they didn't fail.,., will make sure they are covered from contaminiation from now.. may even squeeze some silicon in the splits..?
rather than sily ccccc oning it migh be better to clean them up and try to supper glue them John,
in the mean time i would constantly soak the R clip area in penetrating fluid, the likes of plus gas or diesel fuel
Regards, malcolm.
KP
My Cars:
x 27
Post by KP »
The MOT test for Petrol cats isn't taht bad either if you have LPG and an empty box in the exhaust.
citroenxm
My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising
x 71
Post by citroenxm »
Got News for DPF removal people too!!
Thats NOW a NO NO and failiure if the DPF is removed now! I read that in Auto Express (I think) .....
A very sad...
1994 XM 2.1 d auto
Northern_Mike
Post by Northern_Mike »
That's why you map it out and leave the hardware in place so no one can tell.
DHallworth
Donor 2023
My Cars:
x 125
Post by DHallworth »
Problem with de-cating a petrol and leaving the boxes in place is they tend to resonate through the empty boxes.
We've got two V8 Petrol Range Rover's which run on LPG, both of which are de-cat'd. We tried on one with empty boxes but the noise was horrendous so we got some pipe, cut the cats out and welded them in. Noise levels are about the same. We've never failed an MOT test either as they are presented on LPG rather then Petrol so they don't need to be present apparently. One of them was MOT'd last month, the next is due next month.
Also, any car registered before a certain date (1992 sometime i believe) doesn't legally need cats either.
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'09 C5 2.7 HDi Exclusive
‘10 C5 3.0 HDi Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
Post Reply
