Is it this kit I must buy 5270 JK? It seems just this part is not available alone.
LHM leak on the return... any "y" connectors handy?
Re: LHM leak on the return... any "y" connectors handy?
Xantia Estate 1999 2.0 HDI 110
C5 2005 2.0 HDI 138
Nissan Leaf 2018 40Kwh
C5 2005 2.0 HDI 138
- My Cars: Citroens since 1990, BX Diesel, GTI, TZD with 1.9 TD running extra boost before it was fashionable!, ZX Volcane TD, S2 Xantia break 1.9TD, Xantia HDI 110, currently zipping about in a C2 Diesel. C2 died from the dreaded worm, C3 Picasso HDI Exclusive, the adventure continues.
- x 31
I was repairing the larger rubber returns near the doseur valves, I used fuel line and connectors like these :
http://www.ebay.co.uk/itm/Plastic-Barbe ... 43c5eb0b5a" onclick="window.open(this.href);return false;
You might not end up with the same shape, but as long as the LHM makes it home to the reservoir
Do you have any idea about the thickness of the pipes? there are 4 pipes that need to be connected. Are they the same thickness.
Maybe two 3 way connectors will do the job. Can i use the existing pipes ?
Any advice appreciated.
C5 2005 2.0 HDI 138
C5 2005 2.0 HDI 138
