YPDATE:
Ok, removed the door cars, cut thru plastic (neatly ) and inspect runners etc, all VERY clean and well lubricated.
Did a BSI reset....window problem still evident.
Did a Bsi reset, cleaned and lubricated window runners....window problem persists.
BSI reset, stripped switch down to circuit board, cleaned between contacts with dental probe, sprayed with cleaner, polished contacts, ....window works perfectly.
Looks like (buggered if I could see it ) some dirt inside the switch...result
Post BSI Reset.... Window retrain
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1297
- Contact:
Re: Post BSI Reset.... Window retrain
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- qprdude
- My Cars: Renault 5 TS, Renault 14ts, Citroen C5 Mk1, Renault Clio sport, Renault Laguna Privilege. Citroen C5 X7 Exclusive. Citroen DS5 D/sport . And around 25+ other brands from Morris Oxford to S Type jag and most things between.
- x 10
Cleanliness is next to........................................................................a working electric window.
Rick.
2013 Citroen DS 5 D/Sport
