V6 Xantia......... the beginning of another adventure
Trainman
(Donor 2018)
x 12
Re: V6 Xantia......... the beginning of another adventure
Post by Trainman »
Today, we've changed the water pump and timing belt, and to be honest. It's turned out to be a good idea, the top engine mount was shot
As was the the spring tensioner
The water pump showed signs of leaking, not to mention being a complete pain to remove.
So all that has been done. Tomorrow we tackle the little jobs.....
x 520
Post by xantia_v6 »
The engine mount could be a problem... they are unique to the Xantia V6 and have been. nfp for about 4 years.
x 1784
Post by CitroJim »
Well done Paul and Steve, an excellent couple of days' work there =D>
Is that the auxiliary belt tensioner that's poorly?
xantia_v6 wrote:The engine mount could be a problem... they are unique to the Xantia V6 and have been. nfp for about 4 years.
Time to look at making up a substitute on the lathe maybe :wink:
There are many suspension bushes of a similar size and one of the may do but maybe will need a packing ring to make it the right size.
Paul, you know where to send the broken engine mount - my way!
Trainman
(Donor 2018)
x 12
Post by Trainman »
Best take it out of the boot of mine then...... I'd planned taking it home to get a replacement bush fitted....... ah well..... plan B it is then.......
Today will see us doing the odds and sods of things, things like the switch on the drivers seat, replacing bulbs and generally giving her the tidy up she needs.
Mandrake
x 428
Post by Mandrake »
But have you put the gearbox on the Lexia yet ???
The suspense is killing me. :)
Trainman
(Donor 2018)
x 12
Post by Trainman »
Not yet Simon, it was a bit damp yesterday, don't worry, it's another job for today.
x 520
Post by xantia_v6 »
That rubber is really a vibration damper, it only takes torque reaction, not the weight of the engine. The stiffness of the rubber should be fairly critical. Maybe the rubber ring from a 406, 407, C5, or C6 V6 is similar (but on a different bracket)? .
x 509
Post by RichardW »
Is that the bracket bolted to the inner wing, or the engine one? HDi is still available and the bush may be the same size - albeit spending £30 on a bracket you just going to press the bush out of might be a bit excessive!! The bush on the other end on the HDi is available separately (£26 though!!), but don't know what size it is - I could get a rough measure to see if it is anywhere near.
Edit: actually the engine bracket is still available, but is £93.... :roll:
Mandrake
x 428
Post by Mandrake »
RichardW wrote:Is that the bracket bolted to the inner wing, or the engine one? HDi is still available and the bush may be the same size - albeit spending £30 on a bracket you just going to press the bush out of might be a bit excessive!! The bush on the other end on the HDi is available separately (£26 though!!), but don't know what size it is - I could get a rough measure to see if it is anywhere near.
I suspect its this one Richard:
On the engine near the right wing. That picture is my car - looking at the picture I just noticed for the first time what looks like a shim in the side of the bush ??? Surely that's not original. :lol:
x 1784
Post by CitroJim »
That's the one and yes, the Autobox ECU findings are holding me in suspense too..
citroenxm
x 50
Post by citroenxm »
:rofl2: :-** :-** :-** :-** :-** :-** :-** :-** :-** :-**
addo
Sara Watson's Stalker
x 5
Post by addo »
I am struggling to suppress my urge to stir you back. :lol:
Trainman
(Donor 2018)
x 12
Post by Trainman »
Well, I've just got back home. 4 hours journey thanks to the traffic on the M56. I will do a full post tomorrow with pictures.
Oh and the gearbox.......
Nothing...... that's right.... Nada, zilch, zip, nowt....
citroenxm
x 50
Post by citroenxm »
Ohh crap Steve... Poor you.
Id heard from sally traffic the M56 was bad..
Glad your back ok.. Cheers again..
Mandrake
x 428
Post by Mandrake »
Trainman wrote:Well, I've just got back home. 4 hours journey thanks to the traffic on the M56. I will do a full post tomorrow with pictures.
So there is something wrong with your Lexia then ?
Did you try the adaptor cable from Paul's on yours to see if it was just the cable ?
