DONE!
Thanks very much for all help guys.
Along with clutch I also replaced all these parts that was suggested in this post along with replacement oil!
Fork release pin came out very easily (thank goodness).
Just to note:
I only needed to pull both drive shafts out of gearbox and tie them back out of the way instead of removing altogether
Superb. Went without a hitch and clutch is now ten times lighter and without any grabbing or juddering. Left knee will survive another few hundred thousand miles.
Cheers!
Xantia clutch replacement by dropping end of engine down?
Xantia clutch replacement by dropping end of engine down - D
Citroen Xantia 1.9TD 1996 estate 100% veg 323k
Ford Transit Tourneo 2.5L Di 1999 165k
Yamaha R1 1999 26k
Kawasaki ZXR750 L1 1993 66k (to LPG?)
Suzuki Bandit GSF400 1992 x 2
Mountain bike, skateboards, snowboards, surfboard, longboard and feet!
Yamaha R1 1999 26k
- (Donor 2021)
- My Cars: 2010 C5 X7 2.0 hdi 160 exc auto
MG TF 135
Boxer II 2.2 camper conversion
BMW R1200RT
BMW K1300 R
Honda V F R 800 5thG / MT500 Armstrong - x 39
Re: Xantia clutch replacement by dropping end of engine down
good work Romie
good to hear its sorted,romie wrote: Just to note:
although i would think if the O/S CV joint is still attached/fitted to the hub, this would make it very difficult to drift the intermediate bearing out of its housing,
so i would still prefer to remove that one at least
Regards, malcolm.
- x 3
I normally leave the o/s shaft in the hub, it doean't make knocking the intermeadiate bearing out any more difficult, but I always take the n/s shaft right out to give more room. Whatever makes you happy I suppose!
Cheers!
I did have the advantage of being able to do it over two full days, (embarrassed face).
Very low stress with ample tea breaks
Once the drive shaft was clear of the intermediate bearing housing, I did use a ratchet strap hooked to the centre door pillar allowing me to pull the rhs hub and drive shaft a full inch! clear of the diff
Yamaha R1 1999 26k
Yamaha R1 1999 26k
- CGATCX25GTITURBO
- Location: IN FRONT OF THE LAP TOP Residing in Hull, East Yorks
- x 9
for 10 mins of work I take the shafts out
Neil aka CGAT
1986 CX25 GTI TURBO 1 SERIES 2 'CGAT'
1998 XANTIA 19TD ESTATE
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
1989 CX GTI Turbo 62k miles in a barn since 2001, project started 2023.
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
