Ford Prefect, you have misunderstood my comment.
The ESP system uses a brake fluid pressure sensor in its metrics, to determine appropriate responses. This sensor is integral to the ESP/ABS control unit, and failure is common across many marques and models. There are only two repairs - replace with same and wait for next failure, or replace with re-engineered aftermarket part that doesn't have same risk. Both are quite expensive, and I have seen workshops in denial about the cause of this problem.
I can also state from my own in-car testing of faulty ESP units that if it's only the pressure sensor at fault, basic ABS still functions perfectly.
Citroen c5 Warning light - looks like soft-verges
- Ford Prefect
Re: Sv: Citroen c5 Warning light - looks like soft-verges
addo - right - I was a little quick there
Skickat från min HTC Desire X via Tapatalk 2
Owns: C5 X7 2.0 BlueHDi Saloon
Previous owned: C4 Picasso, XM (rebuilt to a Pick-up), Xantia TCT Activa, C5 2.0 SX Breake, Xantia 2.0 16 Valve Breake, SAAB 900, Audi 80, SAAB 99
