S1 V6'ers, tell me then...
Mandrake
My Cars:
x 666
Re: S1 V6'ers, tell me then...
Post by Mandrake »
taffy wrote:somekind of relay that ive never heard before is clicking either where theses relays are or poss under the ecu...i put key in and turn it to prestart and a relay clicks and then clicks again and the imobiliser light starts flashing and beeping...its not fuel relay or ecu as have held them as the click occours....is there anything under the ecu box perhaps?
If the immobiliser light on the dash starts flashing when you turn on the key it means the CPH didn't receive the correct code from the transponder in the key. None of these clicking relays you hear will have any bearing on the problem.
It's either:
* Faulty transponder in the key
* Faulty antenna on the ignition barrel
* Faulty CPH
* Faulty wiring to the CPH.
Given my similar issue I'd say a faulty transponder antenna on the ignition lock is the most likely. They're quite easy to change if you can get a replacement - three screws to take the steering shroud off, unplug it and slip it off the barrel. Getting the steering shroud back on is the fun part. :twisted:
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
taffy
My Cars:
Post by taffy »
thanks for replys guys i just found whats wrong....my fault....ecu connections wernt the best after me doing testing and give it a wiggle and its all good now lol...silly me i make too many mistakes
99 silver 2.1td exclusive xantia
99 red 2.0 hdi exclusive xantia..
00 black 2.0 hdi exclusive xantia
99 blue 2.0 hdi exclusive xantia
06 silver 1.6 hdi vtr c5
57 blue C4 GP 1.6hdi exclusive
08 black C4 GP 2.0hdi vtr
citroenxm
My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising
x 71
Post by citroenxm »
and does she start????? .............
A very sad...
1994 XM 2.1 d auto
taffy
My Cars:
Post by taffy »
no still dont start :( was very lucky thou not being the key and all that phew!
Post Reply
