ahh not sure..
Jim got a headache on this a while ago.. pretty sure it was a coupe 406 (which are only 2.2) box for a V6 xant.. something was different, sure it was the ratios or change up points or something ;;
4hp20 gearbox has developed a whine
Re: 4hp20 gearbox has developed a whine
I'm sure I remember CitroJim saying that the XM with ES9J4 has a 4HP20 with a different final drive ratio to the 4HP20 in a Xantia with the same ES9J4 engine. Not only that but the ECU is programmed differently to accept the different final drive ratio, so the final drive ratio of gearbox and ECU have to match otherwise the ECU throws up a fault code.
Jim's XM has a 4HP20 from a Xantia fitted and only works properly when a Xantia gearbox ECU is fitted!
Aside from final drive ratio and the presence or absence of a dipstick I'm not sure if there are any other significant variations between different 4HP20's...
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
Yep that's the case, I think (FYI) it's about a 5% difference, with the XM being longer.Mandrake wrote:I'm sure I remember CitroJim saying that the XM with ES9J4 has a 4HP20 with a different final drive ratio to the 4HP20 in a Xantia with the same ES9J4 engine. Not only that but the ECU is programmed differently to accept the different final drive ratio, so the final drive ratio of gearbox and ECU have to match otherwise the ECU throws up a fault code.
I know the torque converters are different between them and i've got a feeling the gear ratios are different as well between the 2.2 HDi and the ES9.
Regarding the offer of a box I strongly suggest you get a reconditioned TC in there, don't use a second hand one (unless you know it's history and has very low miles). Getting your one recon'd isnt expensive and it tends to be the TC that fails that throws its crap into the filter blocking it, starting a wonderful cylce of pain and damaged bank balances.
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2006 C3 1.6 HDi SX,
1971 D Special
2006 C3 1.6 HDi SX,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
