Very......ohhh la fecking lala if it is that
What engine you need the pump for ??....I know of a good one in my ex C5 2lt 8valve and one local in a 1.6 tdi out of a Pug....
Broke down, now will not start.
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1296
- Contact:
Re: Broke down, now will not start.
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
2.0 pump no good completely different.. needs to be from the 1.6 16v engine.. with the turbo on the front..
Citroen c4 2006 56 plate...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- Stickyfinger
AX, little Daffodil
- Contact:
the one in Wanstrow Somerset, is from a 56 plate Pug......I think its the same engine/pumps etc....
Needs to be same as yours so you can compare it with your engine.. the pug is the same things anyway.
Needs to be good and cheap as possible..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- Location: London near that big building with the flashing light!
- My Cars: 2001 Xsara Picasso 2.0 HDi
- x 8
Ford/fiats could be same as they use that engine mind you ford use alot of Delphi
- Stickyfinger
AX, little Daffodil
- Contact:
Give them a call and see mate
http://www.byrnemotors.co.uk/" onclick="window.open(this.href);return false;
- Stickyfinger
AX, little Daffodil
- Contact:
SitRep
The car has now done 1500 miles....not a single miss fire
Starting is fine
Only bleeps at start up.( seats still need to be wired in)
Seems the EGR sensor elec- plug is a weak spot and always worth popping off, clean and replace.
Seems that Seat and AirBag wires need careful checking INSIDE the plastic "protector strip box" ! it had rubbed on the sharp edges of the plastic ....well done Citroen
So ...all well now....THANKS Guys...
Starting is fine
