You'd make enough if you brake it up..
All systems fail? Then that will be a main feed pipe, HOWEVER, the 2.5 td uses the Xantia 6+2 type setup where the steering is powered directly off the pump which makes me think its a main feed pipe at the front.. They also have anti sink fitted too like the Xantias..
Citroen XM 2.5 diesel. any good?
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Re: Citroen XM 2.5 diesel. any good?
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
It's just had a new pump fitted to try and cure the fault. Apparently it runs and drives fine but occasionally everything stops working, but then suddenly it all starts working again. Great for road safety!
Is a valve sticking somewhere?
Its basically the same system as the Xantia.... so NO..
It has to be sucking air in somehwere... Tim, where is the car by the way??? Got a feeling about something... Not in Builth Wells??
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
No, it's in Worcester!
So, could it be a case of checking the main feed pipes for leaks and then driving off into the sunset?
Im not gonna yes or no, as I DO NOT want to be resposable for any mishaps..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
It's ok, I'll instruct whoever is dealing with my estate to absolve you of all blame
- My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1206
There are a number of members on here who run them and even more on the XM forum so you shouldn't be short of help, enjoy.
Good point peter.. tim . Join us on club xm . C o . U k....
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
