MOT tomorrow (wish me luck!)
'13 3008 1.6 HDi GripControl - x 1002
Re: MOT tomorrow (wish me luck!)
I've not had an advisory on obscured pipes.... There is a picture in the Visa Haynes manual thought that makes me laugh - picture of the inboard end of the 2-cylinder drive shaft with the caption "Engine removed for clarity"
- Old-Guy
- My Cars: 2011 Grand C4 Picasso VTR+ 1.6HDi in Kyanos Blue
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - now owned by XanTom
1998 Xantia 2.1 VXD Estate in Mauritius Blue - R.I.P. (terminal tin-worm) - x 17
Great news!Mandrake wrote:No advisories at all this time.
Last year there were advisories for minor exhaust leak and handbrake cable out of adjustment, both of which have been fixed since, however there was also an advisory for "minor cracking" of front brake flexi hoses, but no mention of it this year and I've not touched them... it goes to show how arbitrary some of these marginal calls are...
I'm a bit surprised and disappointed that I didn't get an emissions test print out this time, given the dramas with intermittent misfires, dodgy oxygen sensor, concern about the well being of the cat, etc...it would have been nice to see the exact figures and compare them to last years test...
Is an emissions printout something optional you have to ask for ? I got one without asking last year so just assumed that you normally get them. Can I look it up online or do I need to phone them to get a copy posted out ?
For the last 2 MoTs the green one had similar advisories on the front hoses (still not done and I too can't see what the warning was for). I think whether you get an emissions print depends on whether the tester bothers to print one out (bearing in mind the machine is linked to DVLA). No idea if you can look it up - I would "let sleeping dogs lie" just in case the tester entered the equivalent of "N/A" for the emissions test.
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - after 11 years now owned by XanTom
Too late to let sleeping dogs lie, they're posting me a copy.Old-Guy wrote:I think whether you get an emissions print depends on whether the tester bothers to print one out (bearing in mind the machine is linked to DVLA). No idea if you can look it up - I would "let sleeping dogs lie" just in case the tester entered the equivalent of "N/A" for the emissions test.
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
- DHallworth
- Donor 2023
- x 125
Simon,
Do you know who served you at Glasgow Citroen? I only found out the other day that a girl I've known for years from another dealership has started working there.
What did the main agent charge you for an MOT if you don't mind me asking?
David.
David.
'98 Xantia Activa V6
'00 XM V6 Exclusive
'09 C5 2.7 HDi Exclusive
‘10 C5 3.0 HDi Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
Well I've received a copy of the emissions report Jim, and I kind of wish I hadn't. It barely scraped through by a hair, when it flew through with flying colours last year.CitroJim wrote:Excellent news Simon...
Did you get an emissions printout per chance?
I'd like to see it
Here are the figures last year versus this test:
Fast Idle:
CO - last time 0.039%, this time 0.27%, Limit 0.3%
HC - last time 15 ppm, this time 47 ppm, Limit 200 ppm
Lambda - last time 1.020, this time 1.01, Limits 0.97 - 1.03
Natural Idle:
CO - last time 0.035%, this time 0.49%, Limit 0.5%.
Not good at all In fact I have to say the CO reading looks like they either tried a few times to get it to pass or fiddled it slightly...(not that I'm pointing fingers, but it does look odd )
Obviously the question foremost on my mind is whether the cat has been destroyed from running with a misfire for a while last year, or could a currently occurring (during the test) ignition misfire also give high CO readings ? (Eg if the cat was being overwhelmed with a cylinders worth of un-burnt fuel and oxygen could that result in both high CO and high HC without the cat necessarily being faulty ?)
There are definite symptoms of an intermittent ignition misfire in the last 6 weeks or so, ever since the new coil pack failed, I put the old one back which was better but not 100%, which is why I'm getting a coil-pack from the car KP is breaking...
Simon
1978 CX 2400
1978 CX 2400
PM sent.DHallworth wrote:Simon,
David.
Simon
1978 CX 2400
1978 CX 2400
- CitroJim
- x 6204
- Contact:
Got through that one by the skin of your teeth Simon!!!
Your cat is very tired and near the end of its ninth life...
Lambda's good so there's nothing fundamentally wrong with mixture control
Those figures are also typical of a kitten so don't fit one of those...
Have a natter with Will (KP) about retrieving the cat from his scrapper...
Basically a good ES9 with the original cat in good order should return infinitesimal figures for CO and HC... Without a cat they're a tad on the mucky side..
- CitroJim
- x 6204
- Contact:
I'm sure Will's will be cheaper Adam...
Thanks for the suggestion Jim, but we have absolutely no idea whether the cat on KP's breaker is any good...remember it failed the MOT on multiple points.
I'm pretty gutted but I won't be throwing any money at a cat just now, it's next years problem...
There's also no point in changing the cat when the engine is still not running properly as a misfire or something similar will be what killed the cat in the first place, if it is indeed faulty.
Let me try to sort out the running problems first, if I can get the engine back to normal performance then I'll get the emissions retested and consider my options from there.
Simon
1978 CX 2400
1978 CX 2400
- My Cars: C5 V6 Mk1 assainated by wife
Renault Kangoo 1.6 auto, tarted up and remapped
Still missing the Xantia V6
Not missing the AX - Contact:
But they don't half sound niceCitroJim wrote: Without a cat they're a tad on the mucky side..
Lexia ponce
Lexia ponce
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3008
Simon, if the cat is available from KPs' car I would grab it. At worst you have something taking up space, while you might end up with a useable cat that is the right one for your car and keeps her on the road for a few years to come.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- CitroJim
- x 6204
- Contact:
James, I quite concur...
- CitroJim
- x 6204
- Contact:
Re:
Or run it between MOT tests...addo wrote:I'd make it a decat test pipe. For the price of a gasket kit and two clamps you could run it for a few days to see how the car goes.
