mine are the double right angle type, are yours mandrake? i'm wondering if they supply one part with and one not. Mine didnt come in a box, just a sealed plastic bag so that might shed some light on it
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2006 C3 1.6 HDi SX,
Chris570 wrote:mine are the double right angle type, are yours mandrake? i'm wondering if they supply one part with and one not. Mine didnt come in a box, just a sealed plastic bag so that might shed some light on it
Mine are: one right angled end and the other end is straight though, (the end whose ball joint keep popping out).
Cheers, romie
Citroen Xantia 1.9TD 1996 estate 100% veg 323k
Ford Transit Tourneo 2.5L Di 1999 165k
Yamaha R1 1999 26k
Kawasaki ZXR750 L1 1993 66k (to LPG?)
Suzuki Bandit GSF400 1992 x 2
Mountain bike, skateboards, snowboards, surfboard, longboard and feet!
Mine were both the earlier type with only one right angle. I think addo has already solved the mystery a couple of posts up anyway. Looks like the double right angle ones come with them and the earlier ones don't.
Why is anyone's guess. It sure is annoying to receive them and then realise you have to make an extra trip to go buy nuts and washers to do the job. I was caught out both times.
Does anyone know for certain whether washers were fitted at the factory ? I fitted washers on both cars and I have a vague recollection of my earlier Xantia having washers on the nuts on the originals. I know a lot of people don't fit washers though, and it probably doesn't matter either way.
Simon
2011 Peugeot Ion Full Electric in Silver 1977 G Special 1129cc LHD 1978 CX 2400 1997 Xantia S1 2.0i Auto VSX 1998 Xantia S2 3.0 V6 Auto Exclusive
My Cars: 2011 Grand C4 Picasso VTR+ 1.6HDi in Kyanos Blue 1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - now owned by XanTom 1998 Xantia 2.1 VXD Estate in Mauritius Blue - R.I.P. (terminal tin-worm)
Mandrake wrote:The Lemforder ones don't come with nuts or washers for some reason. I just bought a small bag of standard nylock nuts and washers from B&Q when I fitted mine. Did you fit washers on yours ?
They used to, but don't anymore. Asked the question last time I bought a Lemforder drop-link from GSF (as I'd destroyed both nuts getting the link off) who then supplied the wrong size. Fortunately, I managed to 'borrow' a pair of new Nylocs (had to order up a bag of 10 to replace the 2 loaned nuts). Managed to find the remaining 7 recently when replacing a drop-link for the VSX's MoT.
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - after 11 years now owned by XanTom
Your local B&Q have a bag of the right size (size depends on year of Xantia) nylock nuts and washers on the shelf for just a few quid. They're not usually a good source of car related parts (although some of their tools are decent) but in this case they have the goods.
I took the new drop link in the store with me and tested the size of the nut through the plastic bag to make sure I had the right size.
Simon
So fitted the Lemforder drop link. And smothered threads and hex drive holes in copper grease - again.
Was a bit of a pain to get this one in-between the two mounting points this time round.
Had to raise the suspension to max, prop front end up with axle stands. Then lower suspension to min and shove suspension up by the brake disc to get the drop link between the mounting points.
Am sure it wasn't this difficult last few times!
This led me onto thinking about the length of the link. Too short would def make this happen!
Unfortunately I didn't think to measure the Q-Drive parts, although according to ECPs site it was correct to my reg number and vehicle type. Also it was a 12mm thread.
Measuring the Lemforder part it was roughly 32cm, (mounting hole to mounting hole).
No help to me now, but no doubt I'll be checking on here again for this measurement on the next drop link I get in a years time! :p
So the Q-Drive parts were Euro Car Part, part number: 600545120
The Lemforder part number from ECP is: 600545125
I should go in and ask to measure that Q-Drive part to rule that out :/
And I should measure against the other side! Will crack on with that tomorrow.
Anywho, Lemforder part now on test!
Cheers guys, romie
Oh, interesting that you now have to enter the promo code displayed on the first page of ECP website to get 30% off - meaning back to the normal price. Basically they've raised the prices and added an extra step making the entry of a promo code necessary to get back to the original price! >:(
Are GSF and ECP the same people? They have exactly the same structure to their web pages?
Yamaha R1 1999 26k
romie wrote:Are GSF and ECP the same people? They have exactly the same structure to their web pages?
GSF is the trading name of German Swedish & French Car Parts Limited, a private limited company with 16 shareholders.
Euro Car Parts was acquired by the American LKQ Corporation in 2011.
So no, they are not the same people.
More likely they contracted the same web design company to design the website for them, or that both companies are using the same sort of CMS (content management system) and using a turnkey ecommerce design that is close to one of the template designs...
Its not the first time I've seen unrelated companies with similar looking web stores!
Simon
