Xantia, new headunit and CD changer. NEW WIRING PROBLEM!
Re: Xantia, new headunit and CD changer. NEW WIRING PROBLEM!
The xantia in the breakers has gone so I deffo need help finding this damn lead!
Oh, and every channel has hissing. its the same with the engine on or off. Annoying.
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 70
IF the aireal will unscrew in the Roof mount, remove it, clean the threads up of corrosion and if you can fit a LONGER aireal.
My Clarion unit would always loose chanel, RDS search, and pig about, I removed the arieal, and fitted a longer XM aireal and now the channel NEVER rds search's or goes off at all!!!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Good idea, I'll hit the the breakers again and see what I can find. My existing Ariel its a bit corroded though!
My existing aerial was really corroded where it screws into the base but with a pair of pliers it was eased loose. With the threads cleaned up there is a definite improvement in the radio reception. I recon a new aerial will do the trick though!
Just need that lead now! (hint hint)
