Help! Split hydraulic line
addo
Sara Watson's Stalker
Location: NEW South Wales, Australia. I'll show you "Far, far away" ;-)
My Cars: Peugeot 605
Citroën Berlingo
Alfa 147
x 93
Post by addo »
You could make it up with the blingy blue hose - fluoropolymer lined silicone hose - and aluminium joiners with the single use squeeze clamps.
isisalar
My Cars:
x 3
Re: Help! Split hydraulic line
Post by isisalar »
If you want to DIY it something like this would be ok for routing the pipe:-
http://www.discountleisureproducts.co.u ... gs-c20#c88" onclick="window.open(this.href);return false;
If you need a pro job these are the guys http://www.pirtek.co.uk/service-centre- ... drVPPK9FFA" onclick="window.open(this.href);return false;
If you go and visit them they can be very reasonable.
Cheers
Paul
J reg 1.9d auto BX first Citroen
M reg 1.9d auto Xantia lx
N reg 1.9 td Xantia VSX Estate
T reg 2.0HDI Xantia Exclusive Estate Present car
M reg 106 diesel red
L reg 106 diesel white
02 Saxo 1.1i desire wife's present car(sadly now very ill cambelt gone- Doh)
Dommo
My Cars: Current
07 C5 VTX+ 2.2 HDi 173hp
97 S1 Activa
06 Boxster S
93 XM 2.1 Turbo SD
Previous cars
91 Toyota Soarer UZZ32 Active Suspension
97 S1 VSX 1.9 Turbo D
99 Xantia Activa
98 2.1TD Xantia
99 306
x 19
Post by Dommo »
I managed to get 11mm pipe on an 11mm and 13mm spigot with no adaptors, it takes a bit of a shove but it goes on easily enough!
Post Reply
