Location of radiator fan switch
mitch13
My Cars:
Re: Location of radiator fan switch
Post by mitch13 »
Hi, I have had the Auto spark just bypass the fault, and run a switch from the dash to the fan relay; which cuts out the ECU. Total cost was £150 :shock:
1) Diagnostic machine to check for location of fault £35
2) one hour to check for any obvious faults and relays, loose or corroded wires etc. £40
3) replace corroded wire at alternator £20
4) run bypass switch to relay £60
5) total £155 for 3 to 4 hours work, so he says :x
Not sure if this is the going rate but it seems a little steep to me :?
I think I should have been a auto electrician not a bricklayer :lol:
Thanks for the help, hope the thread helps others; if only to avoid auto sparks at least :wink:
addo
Sara Watson's Stalker
Location: NEW South Wales, Australia. I'll show you "Far, far away" ;-)
My Cars: Peugeot 605
Citroën Berlingo
Alfa 147
x 93
Post by addo »
Anyone on a trowel here wants in excess of £250+/day.
Post Reply
