stopped for 5 min. temp gauge in red..................
Re: stopped for 5 min. temp gauge in red..................
it was registered in mar 01 (iirc), dunno when it was actually made though.
what all this multiplexed thing about?
Citroen Xsara Picasso
Subaru Impreza WRX
Nissan Primastar
Subaru Impreza WRX
Nissan Primastar
- Sara Watson's Stalker
- Location: NEW South Wales, Australia. I'll show you "Far, far away" ;-)
- My Cars: Peugeot 605
Citroën Berlingo
Alfa 147 - x 93
Multiplexed ones have a BSI instead of the fusebox like your 1.8, and a COMM2000 stalk set.
They use only one sensor to control the fans, the water temp gauge on the dash and the engine fuel injection ratio. Earlier cars used three sensors separately for these purposes.
In your case, if the sensor is crook it will affect the temperature readings on the dash, the fuel economy and the fan operation.
economy seems fine, only driven it 1 time though, fan didn't kick in when the temp went high, temp gauge seems to work ok.
Subaru Impreza WRX
Nissan Primastar
Subaru Impreza WRX
Nissan Primastar
Before you start to rip the engine apart as it seems is always the first line of action
given by the 'experts see at what temperature the fan cuts in if at all.
The world is full of them and a lot are in
When it get too hot near 100 Deg. wiggle the multi plug at the fan it could be corroded
well it didnt cut in when it went to the red.mendedit wrote:Before you start to rip the engine apart as it seems is always the first line of action
Subaru Impreza WRX
Nissan Primastar
Subaru Impreza WRX
Nissan Primastar
how do i know when it hits 100 degrees though?mendedit wrote:When it get too hot near 100 Deg. wiggle the multi plug at the fan it could be corroded
Subaru Impreza WRX
Nissan Primastar
Subaru Impreza WRX
Nissan Primastar
Well, normally the gauge pointer when at running temp. will be at or very slightly before the centre
(middle) marker then will rise to somewhere below the third or 3/4 mark at that point the fan should cut in
sending the pointer back down to the centre again then switching off the fan and so on.
If it climbs above the 3/4 mark the fan should be running,
In the red for to long will warp the head...lot's of £££££££££'s
- Ben82
- My Cars: C5 V6 2004
- x 7
Having it hooked up to a lexia whilst driving and getting the issue should narrow down what it is. You'll at least be able to get the coolant temperature reading, and possibly whether the fans should be active or not.
You can see if there's any members in your area with a lexia here: http://www.frenchcarforum.co.uk/forum/v ... 19&t=29178" onclick="window.open(this.href);return false;
2004 Citroen C5 3L V6 Auto
Brit living in Sweden with an imported from Germany French Car!
well not really as ive been offered another engine for £100 with a 3 month guarantee.mendedit wrote:In the red for to long will warp the head...lot's of £££££££££'s
Subaru Impreza WRX
Nissan Primastar
Subaru Impreza WRX
Nissan Primastar
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
TU engines are rather common, and not expensive these days. Went into a LOT of PSA cars due to its long life from 1985 to around 5 years ago?
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
I quite agree
head gasket failure results in coolant no? its using no water.
Subaru Impreza WRX
Nissan Primastar
Subaru Impreza WRX
Nissan Primastar
