2.0 hdi running rough white smoke fault codes...
Re: 2.0 hdi running rough white smoke fault codes...
No problem, guarantee that was the problem, timing out valve hit piston and broke rocker like it should do but NOT when I had a hdi! Make sure she's all timed up correct in the cam timing holes. Well done.
Xantia 1.9 TD 1993 (sinker)
- CitroJim
- x 6182
- Contact:
Delighted you've found it Taffy.. I expect the rocker was initially weakened when the pump went and then lost the will to live on the restart...
yea I think it must off...all those fault codes thou..goes to show The ecu knows a lot
99 silver 2.1td exclusive xantia
99 red 2.0 hdi exclusive xantia..
00 black 2.0 hdi exclusive xantia
99 blue 2.0 hdi exclusive xantia
06 silver 1.6 hdi vtr c5
57 blue C4 GP 1.6hdi exclusive
08 black C4 GP 2.0hdi vtr
all done and finally running agsin!! Oh happy day! Thank you so much for your help guys I couldn of done it without you!
Well done, bet you were over the moon when she fired up!
- CitroJim
- x 6182
- Contact:
Taffy - Fantastic
Ah mate I felt a tear after all we been throu! She's purrin real sweet jus had an incodent with high pressure hose by The pump iv had to cut it short as The rubber had split but all good now...thinkin it might have been suckin air in hence my problem with constantly ticking...mot next new windscreen bottom ball joints and tyres and Ishes bk!
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Well DONE Taffy, Deafenatly deserves an applause..
You have worked well,
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
thanks paul
