Pete, you need a half-moon 13mm ring spanner to get the lower flange nut off tthe pump and it's fiddly evven then..
Basically lock the crank, cam and pump sprockets as if doing a cambelt but you don't actually need to remove the belt as long as you use two pins (8mm studs) in the pump sprocket.
Loosen and remove the pump sprocket nut (21mm)
Disconnect and remove the injector delivery pipes, disconnect all other pipes and cables.
Loosen the three pump flange nuts but don't remove them all just yet although you can remove two... Don't loose the special washers
Use the special puller - details later - to break the taper on the pump drive sprocket.
Loosen and remove the the back mount nut, bolt and special washers.
Stuff lots of rag around the sprocket.
Remove the last flange nut and washer. Pull the pump gently backwards, watching for the woodruff key on the drive shaft. That's why you stuff loads of rags around as it has a habit of making a bid for freedom..
You can now remove the pump.
You will need this puller:
This is the plan to make one:
This is the puller in use (engine removed for clarity):
Hope that is enough to get you going Pete...
Any more questions, just shout..
