Repairing split battery terminal ?
Re: Repairing split battery terminal ?
I wanted one that wasn't going to split again Jim, that thing is really heavy duty! It's not as shiny as it looks actually, the flash must have done that.
- Xaccers
- x 184
Quickly installed photoshop, found a suitable image of the new terminal, removed the back ground, pasted it over the old terminal, stretched it a bit, then deleted the part that would be behind the old terminal.superloopy wrote:Xac ... On a second look .... how did you 'edit' Simon's original photo? Just interested
DIY sphere tool
DIY sphere tool
- CitroJim
- x 6206
- Contact:
^^ That's clever
so much so the flash has blurred the image so i cant quite make out what the terminal looks likeCitroJim wrote:That's a bit blingy for a battery terminal Mike
the reason the original lead terminals split is through over tightening them over the years,
when the lead terminals are tight on the battery post there should still be a gap,
but im sure most on here will already know this
Regards, malcolm.
- Xaccers
- x 184
I'll try and remember to take photos of my bling terminals on Cassy
I'd really like the one with built in voltage display.
DIY sphere tool
DIY sphere tool
320Nm plus half a turn?citronut wrote:so much so the flash has blurred the image so i cant quite make out what the terminal looks likeCitroJim wrote:That's a bit blingy for a battery terminal Mike
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2006 C3 1.6 HDi SX,
1971 D Special
2006 C3 1.6 HDi SX,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
- Xaccers
- x 184
The BoL says 320Nm plus 3/4 of a turn. That must be what's doing it.Chris570 wrote: 320Nm plus half a turn?
DIY sphere tool
DIY sphere tool
Re:
Nope, don't know where you got that idea.addo wrote:That's a good start. Thought we had replaced the terminals on this car?
Yes. That's why I usually loosen the nut a few turns and spread the clamp slightly with a screw driver to let it slide further down the taper to avoid the clamp closing right up due to sitting too high on the taper.Simon, you know they (terminals and clamps) are conically tapered and differ between P&N, right?
Unfortunately this one seems to be worn too far (or the posts on the fitted battery are not a good match for the clamps) as the clamps do close right up.
It looks fine but I'll get a clamp for that one as well.As a matter of immediacy I would replace the positive at the same time.
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
Only on frenchcarforum would someone go to these lengths to be helpful.Xac wrote:How about this then:superloopy wrote:Wow Xac ... never has the saying 'a picture paints a thousand words' had more meaning . Still haven't a clue what you mean although thanks, a lot of effort went into that :P
Sent from my GT-N7100 using Tapatalk 2
I should have said in my original post though that its not an emergency "It broke and the car doesn't work any more" situation. I've already squeezed the clamp back into shape and put it back on and its holding satisfactorily for the mean time, so I'm not looking to do a bodge, I'm looking for the best way of doing a tidy permanent repair.
Simon
1978 CX 2400
1978 CX 2400
Thanks Mike, that looks like what I want - so you inserted 20mm or so of bared back wire into the clamp and tightened it up ? Is it just the two visible bolts that are clamping the cable into the terminal, and do they clamp well enough to make a solid low resistance connection ?Northern_Mike wrote:I did this on what is now Mungkie's Activa:
New battery clamp with extra screwy bits was about £7 from Halfords. I cut the old clamp off with a dremel, as you can see (it's on the airbox) but you could use a hacksaw then fixed the clamp on and put it all in place. I imagine it's still on the car perfectly secure.
Simon
1978 CX 2400
1978 CX 2400
- Xaccers
- x 184
I got these for Cassy:
http://www.ebay.co.uk/itm/2-x-HEAVY-Gol ... 5657794276" onclick="window.open(this.href);return false;
DIY sphere tool
DIY sphere tool
Mandrake wrote:Thanks Mike, that looks like what I want - so you inserted 20mm or so of bared back wire into the clamp and tightened it up ? Is it just the two visible bolts that are clamping the cable into the terminal, and do they clamp well enough to make a solid low resistance connection ?Northern_Mike wrote:I did this on what is now Mungkie's Activa:
I'm pretty sure that's exactly how it was Simon. I'll root out a better picture. If I remember properly, the part where the bare wire fitted in was "gripped" and a very tight fit. I certainly couldn't yank it out when I tried before I put it back on the battery.
Chris570 wrote:320Nm plus half a turn?citronut wrote:so much so the flash has blurred the image so i cant quite make out what the terminal looks likeCitroJim wrote:That's a bit blingy for a battery terminal Mike
hope that is with a 2 foot knuckle bar and 140 degrees + 140 degrees + half a tirn
Regards, malcolm.
