Leaky HP Pump
Rhothgar
Donor 2023
My Cars: 2013 Peugeot 3008 Allure 1.6HDi - FD63 FWA VF3**************[VIN obfuscated, can be read by forum staff]
1995 Citroen Xantia 1.9TD S1 - M728 GDL VF7**************[VIN obfuscated, can be read by forum staff]
1996 Citroen Xantia 1.9TD SX S1 - N707 MGP (Currrently laid up)
2000 Citroen Xantia 2.0 HDi S2 - X435 JGJ VF7**************[VIN obfuscated, can be read by forum staff] (Clutch died Dec 2017 - Resurrected Easter Sunday 2021)
1997 Citroen ZX SX TD - P788 AJL
1959 Landrover Defender S2 - Two owners from new
1968 Triumph Vitesse Convertible 2.0
1980 Ford Escort RS2000 Customer - 2nd Owner
1988 Saab 900 T16S - A 1980's exercise in understated Hooliganism...
Oh! and two Harley Davidsons - A 1990 Sportster and a 2003 Fatboy 100th Anniversary (the only vehicle I have owned from new)
x 78
Re:
Post by Rhothgar »
addo wrote:Glad to see the HP source is at stake.
You mean rather than the pump as a whole Addo?
addo
Sara Watson's Stalker
Location: NEW South Wales, Australia. I'll show you "Far, far away" ;-)
My Cars: Peugeot 605
Citroën Berlingo
Alfa 147
x 93
Post by addo »
It was a bad pun.
I'm a pump-off, fix it 100% advocate (but didn't want to burden you with this attitude). If you do, make sure to examine how it's aligned, first.
Rhothgar
Donor 2023
x 78
Re: Leaky HP Pump
Post by Rhothgar »
Addo. I'm all for a proper job.
You mean pulley alignment when putting it back on, I assume.
addo
Citroën Berlingo
Alfa 147
x 93
Post by addo »
Yes, the Service.Citroën exploded diagram is wrong in how it lays out the collets and cone nuts.
Rhothgar
Donor 2023
x 78
Re: Leaky HP Pump
Post by Rhothgar »
Has anyone got a 4026 88 O-ring going spare they want to sell?
Citroen want to sell a minimum of 5 pieces!!!
Trying to work out what size it is. It states 19-TO 2.4mm
I assume this means 19mm. To Outside with a 2.4mm. section.
Would a 14mm internal 2.5mm. section O-ring suffice?
Thoughts/verbal abuse please!
Or if anyone needs one, let me know and I can post for cost+postage. Payment by PayPal.
My Cars: Bluebell the AX, Polly the C3 Picasso, Pix the Nissan Pixo, Propel the duathlon bike, TCR Pro the road bike and Fuji the TT bike...
x 6163
Contact:
Re: Leaky HP Pump
Post by CitroJim »
Roger, I'd not try any old ring in this position as it's critical. Some O rings are not LHM resistant.
Five won't cost the earth and you can always sell what you don't need on here. Someone will have them.
Rhothgar
Donor 2023
x 78
Re: Leaky HP Pump
Post by Rhothgar »
5 won't cost much? £6.75 I'll have you know. Hate wasting money!
x 6163
Contact:
Re: Leaky HP Pump
Post by CitroJim »
Rhothgar wrote:5 won't cost much? £6.75 I'll have you know. Hate wasting money!
You're not. Flog 'em on at a profit. Quid a ring with a quid P and P. There you are. Can't say fairer than that...
Look at it this way Roger; five rings are less than a packet of fags and less that a couple of pints of beer. And they're better for your health!
Dommo
My Cars: Current
07 C5 VTX+ 2.2 HDi 173hp
97 S1 Activa
06 Boxster S
93 XM 2.1 Turbo SD
Previous cars
91 Toyota Soarer UZZ32 Active Suspension
97 S1 VSX 1.9 Turbo D
99 Xantia Activa
98 2.1TD Xantia
99 306
x 19
Re: Leaky HP Pump
Post by Dommo »
Looks to me like the accumulator is past it, sounds it too based on the click rate. I'd say the pressure is spiking when the regulator lets fluid through (because of a flat accumulator) which - along with old o-rings - could well be the cause of the leak.
Rhothgar
Donor 2023
x 78
Re: Leaky HP Pump
Post by Rhothgar »
Are you suggesting that a replacement accumulator could be the cure and stop the leak?
x 6163
Contact:
Re: Leaky HP Pump
Post by CitroJim »
Rhothgar wrote:Are you suggesting that a replacement accumulator could be the cure and stop the leak?
It's certainly not helping Roger. Dom makes a good pint there but I'd still replace the O ring as they do go regularly..
Rhothgar
Donor 2023
x 78
Re: Leaky HP Pump
Post by Rhothgar »
I'll go round Dom's tomorrow for a pint of home brew then!!!
Dommo
My Cars: Current
97 S1 Activa
06 Boxster S
93 XM 2.1 Turbo SD
Previous cars
99 Xantia Activa
98 2.1TD Xantia
99 306
x 19
Re: Leaky HP Pump
Post by Dommo »
Rhothgar wrote:I'll go round Dom's tomorrow for a pint of home brew then!!!
Took me a while to get that one... I got there eventually!
Rhothgar
Donor 2023
x 78
Re: Leaky HP Pump
Post by Rhothgar »
What a complete bar steward!
At my mates at the moment doing the o-ring and the car appears to have p*ssed out all its green blood.
I've depressurised the system so I assumed, rightly or wrongly, that the LHM loss would have been minimal.
I have a sneaking suspicion that there is, in fact, NO ball bearing in the pump and until all the LHM drains out, I ain't gonna know.
This is perhaps the reason why the car is clicking so regularly.
Surely with such low pressure in the system I only need to press on the spring and the flow should STOP, which, it isn't doing.
Any thoughts on these comments, guys!
Rhothgar
Donor 2023
x 78
Re: Leaky HP Pump
Post by Rhothgar »
Anyone know the diameter of the ball bearing!!!
And is it a standard steel one or anything special?
Post Reply
