Raspberry Pi anyone?
Post Reply
My Cars: Bluebell the AX, Polly the C3 Picasso, Pix the Nissan Pixo, Propel the duathlon bike, TCR Pro the road bike and Fuji the TT bike...
x 6182
Contact:
Re: Raspberry Pi anyone?
Post by CitroJim »
Splendid stuff Xac..
You know, we'll soon have you extolling the virtues of the vi editor at this rate :lol: :lol:
Xaccers
My Cars:
x 184
Post by Xaccers »
I use nano :P
DIY sphere tool
Mandrake
My Cars:
x 666
Post by Mandrake »
Xac wrote:I use nano :P
I was about to say the same... :) I was sysadmin of many Linux servers for years and used, yep, nano. :twisted: (or pico which was identical) Never felt a need to learn vi or emacs even though I was doing quite a lot of shell scripting and of course conf file editing...all my servers had the default editor changed from vi to nano.
Scrolling, insert typing, cut and paste, search, what else do you need ? :lol: I'm sure I'll loose a lot of Linux geek cred for admitting to never using vi or emacs but who cares... :mrgreen:
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
Xaccers
My Cars:
x 184
Post by Xaccers »
I vaguely remember vi from my days at uni, where I lost my network access for 2 weeks for mudding.
DIY sphere tool
Ben82
My Cars: C5 V6 2004
x 7
Post by Ben82 »
I actually switched from nano to vim about a year or so ago, for one main thing, syntax highlighting :) (yes nano has some, but not as extensive as vim)
I only know a handful of vim commands, but its enough to get me by :)
2004 Citroen C5 3L V6 Auto
Brit living in Sweden with an imported from Germany French Car!
x 6182
Contact:
Post by CitroJim »
That's a girl's editor :twisted: :lol: :lol:
I jest. I only use vi because some of the systems I work on have nothing else so familiarity is essential and regular use of vi is essential so as not to inadvertently make a dog's breakfast of something critical. :(
I even have gvim (a port of vi to Windows) installed on some of my Windows machines... Just for editing stuff destined for the Unix world as Notepad can occasionally have undesirable effects when editing some Unix shell scripts...
I like nano. It's good.
Never ever used emacs...
Xaccers
My Cars:
x 184
Post by Xaccers »
Jim can you cast your eyes over this code
Code: Select all
from i2clibraries import i2c_lcd
from time import *
# Configuration parameters
# I2C Address, Port, Enable pin, RW pin, RS pin, Data 4 pin, Data 5 pin, Data 6 pin, Data 7 pin, Backlight pin (optional)
lcd = i2c_lcd.i2c_lcd(0x27,0, 2, 1, 0, 4, 5, 6, 7, 3)
# If you want to disable the cursor, uncomment the following line
# lcd.command(lcd.CMD_Display_Control | lcd.OPT_Enable_Display)
lcd.backLightOn()
lcd.writeString("Python I2C LCD")
lcd.setPosition(2, 3)
lcd.writeString("For the Pi")
I should be able to add
Code: Select all
message = The rain in spain
lcd.writeString(message)
and have it display The rain in spain on the LCD right?
print(message) would do that.
DIY sphere tool
x 6182
Contact:
Post by CitroJim »
Xac wrote: I should be able to add
Code: Select all
I would tend to agree with that Xac. I looked up the declaration and use of variables in Python and that seems to be good.
Only one way to find out :wink:
Xaccers
My Cars:
x 184
Post by Xaccers »
I tried last night and it just displayed: message
Will have to try tonight.
DIY sphere tool
x 6182
Contact:
Post by CitroJim »
Ummm,
The library that has that function is not following rules. have you looked at the code within the library?
spider
My Cars: Soon, I hope...
x 77
Contact:
Post by spider »
Is this the topic for assembly language ?
* looks around *
No, goes back to his assembler :oops:
Andy.
x 6182
Contact:
Post by CitroJim »
spider wrote:Is this the topic for assembly language ?
By all means Andy... I used to back in Z80/8080 and CP/M days...
Xaccers
My Cars:
x 184
Post by Xaccers »
Eureka I've done it.
Used a bash script to get the temperature (temp=xx.x'C).
I call that within the python script and chop it down to remove the temp=
DIY sphere tool
x 6182
Contact:
Post by CitroJim »
Xac wrote:Eureka I've done it.
Let's see your code then Xac :)
Xaccers
My Cars:
x 184
Post by Xaccers »
The bash script
Code: Select all
#!/bin/bash
#get system temperarure and save as 'sysTemp'
/opt/vc/bin/vcgencmd measure_temp > sysTemp
# this creates a file called sysTemp in current directory
The Python3 script
Code: Select all
import sys, subprocess
# appends to PYTHONPATH the location of the example codes
sys.path.append("/home/pi/quick2wire-python-api/")
from time import *
subprocess.call("/home/pi/temp.sh")
lcd = i2c_lcd.i2c_lcd(0x20,1, 2, 1, 0, 4, 5, 6, 7, 3)
lcd.backLightOn()
def line1():
	lcd.writeString("Current Temp:")
def line2():
	fo = open("sysTemp")
	str = fo.read()
	fo.close()
	lcd.writeString(str.strip().strip("temp="))
lcd.clear()
line1()
lcd.setPosition(2, 0)
line2()
DIY sphere tool
Post Reply
