Yes we was right it was the back breaks. It was pads. One of them was rubbing metal to metal. We gt new pads and discs.
BUT
the retaing bolt snapped off. When we was taking it off. Wheres the best place to get one. How much they cost. Allwoods said we need to get one from main dealer
back break rubbing making nioses xantia
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3007
Re: back break rubbing making nioses xantia
If it is the bolt that holds the pads in situ, then this is what you need;
http://www.eurocarparts.com/ecp/c/Citro ... c4d&000416" onclick="window.open(this.href);return false;
and has all the parts for both sides. You might need to get them ordered in, and inspect them BEFORE you leave the branch. I found that the first set I ordered had a split bag (and bits missing). The next day the set that arrived was intact, and had been checked before I got to the branch.
How are the callipers? Are they lined up correctly, or has the calliper corrosion shown up?
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Need to get them for tomo. Manged to get a day off work. Surly citroen have got them in.
Did the 40 have disk s at the back ? Would they have the same part as citoren ?
- Donor 2023
- x 3007
I wouldn't know about Citroen, as I got mine from ECP (cheaper). Even with dealerships some parts have to be ordered in.
Sorry, but what is a 40?
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
406lol
Theres a store in Lincoln
So i might be saved Just hope they have them in
- Donor 2023
- x 3007
Ah, right. Sorry, but there you have me stumped, as I have no knowledge of Peugeot cars (although I run a Pug Partner van, company supplied), and it has drums on the back.
Don't forget the copper grease when you fit the new bits. If you haven't already done so, smear some on the faces where the disk contacts the hub. Otherwise rust will build up over time, and bind the hub and disk together. This has happened on Gracie, and I am having to use Plus Gas (also available from ECP) over time to break down the rust so I can replace her disks.
Which bolt failed? Please let it be one in the kit I posted to!! otherwise you could be into a world of hurt. The two calliper bolts are high tensile (so they cannot be drilled out), and IIRC somebody on the forum snapped one of them, and MIG welded a nut onto it so that it could be undone.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
least after all o this. Ill have a solid car. With the knowledge. That all the breaks are brand new and pads. Theses discs are called apec
- CitroJim
- x 6182
- Contact:
No, as the handbrake works on the rears of the 406 so pads will be very different...jacksun1987 wrote:Need to get them for tomo. Manged to get a day off work. Surly citroen have got them in.
Did the 40 have disk s at the back ? Would they have the same part as Citroën ?
SORTED THANKS
just need to get the fount sorted out. Then the passeger door. Not to bothered about tyers. Then ill love to try and find. Somwhere to re gas the sphers then DONE
