Been a while since I last posted here, but I have been lurking around a lot, so haven't been gone completely. We now use the car a lot less than before... Daughter catches the (public) bus to school, and rides the school bus most of the way back home, and uses her scooter the rest of the way. That will most likely only last whilst the weather is good, and no doubt I will probably need to pick her up from where she gets dropped off by the bus.
A few things have happened with the car since last October
The "I'm not starting" problem seems to occur once a quarter these days now, so nothing too major.
When I changed to the Summer tyres around June/July time
one of the bolts sheared on the rear drivers side, I panicked and took it to the local garage to get sorted. In hindsight, I possibly could have tried sorting it myself, but might have not had the confidence to drill into the bolt without damaging the drum.
It gave me a chance to ask the garage how much it would cost to have the 4HP20's oil changed if I gave them the oil; which turned out to be about £35, so I didn't think was too bad considering hiring of the car lift to do the work probably would have cost me £15-£20 alone.
I sort of regret that, as I took the car in, in the morning, and they rang me just before closing time to say that they needed to get something from Citroen to do the rest of the job (they had drained it, so the car was up on the lift without any LT71141 inside), the bit they needed obviously was the filling tool. In the end it wasn't until gone lunchtime the following day that I could collect the car. On the plus side at the time the car seemed better for the oil change but still making the "grumble noise", but now it doesn't seem too different to before, so probably needs another round of LT71141.
About 2 weeks ago, we got some new front tyres, the old ones were *ahem* getting bald. Got some Hankook Ventus Prime 2s on there, they were just Ventus Prime before, was tempted to change to some Dunlop Blu Response tyres for the quoted quieter road noise, but wasn't going to be worth the extra ~£15 per tyre. With the amount of tread on the new tyres it makes me wonder if my winter ones will be legal this year
(They're supposed to have at least 3mm of depth to them to be legal), and I think the rear tyres will probably only get maybe 2 more years.
A few weeks ago I noticed the windscreen wash wasn't spraying, but the pump was running, I tried topping it up to see if it was just lack of liquid, but this didn't seem to be the case. On Saturday the wife and I went to try to see if we could get to it and diagnose it further, couldn't get the bumper completely off due to a surprise of having the gubbins for the headlamp wash and wipe in the bumper, but could tell the pump was running but didn't seem to be pushing anything through the hoses. Put it all back together and ordered a new pump from the UK so will be fitting that after it has arrived. Bandit has given me some tips on the front bumper removal, and the wash bottle, so hopefully will be easier next time. It does seem like some cowboy mechanics had the bumper off at some point..... most of the screws etc were not the same as they were listed in the service docs, one had been replaced with a cable tie as well.
Also on Saturday I changed the pollen filter, which was a bit of a fun job, the filter that was in there didn't have any plastic bits that helped determine where the existing one was, along with the instruction being for a manual gearbox, and the trim being slightly different for an auto. Managed to work out where it was, and get the old one out which was nice and dirty. One credit for the filter in there, it did have a "peep flap" so you could see how dirty it had gotten. Got the new one in and took the car out for a drive to see if there was a noticeable difference, there was, with the old one, there was a bit of a smell (not something that reeked, and unpleasant), but it was noticeable that the smell had gone since putting in the new one.
Today, I finally got around to changing the engine oil on the car, I intended to do it last August, but kept on losing weekends so was really overdue. Only main trouble I had was getting the sump plug started... I first went for the 8mm square socket, but the ratchet wasn't big enough to allow me to budge it, so changed for the larger ratchet with the 24mm socket, which was still very tight but easier to start it off. I noticed the new sump plug that I bought did not have the 24mm socket option, and only the 8mm one, so I kept the same sump plug but just swapped over the half rubber washer. I will probably look for a replacement sump plug that has both options for next year. She guzzled ~5.25l of oil to get to the max marker. I started off with 4l, and kept adding increments of about 200ml each time to get to the max line, as there seems to be conflict as to how much oil the ES9J4S takes. Next time, I will most likely dump the whole 5l bottle in, and go from there. For anyone interested I used the Shell Helix 5W-40 Fully Synth oil in there.
Over the past few months the car seemed to start getting a bit confused with the oil level on the old oil, the digital gauge would often seemingly be random somewhere between max and half way (a difference of about a litre I believe), at least when filling up with the new oil, both the dipstick and the digital gauge seemed to agree with one another, and in the couple of times of taking the car out for a drive since doing it, the digital gauge has firmly been on max, but we shall see if that changes.
Other than the above, there's not really much else to report, she's taken us all the way to Oslo, Stockholm, and to the south of Sweden, without issues. Hopefully will stay that way for at least a few more years
