New MOT's from the dreaded europhobes
x 92
Re: New MOT's from the dreaded europhobes
Post by citronut »
if you fit a pit bull terrier under there after cat removal that will deter the MOT tester :shock: :twisted: :roll: :wink:spoz it would remove the cat for you as well
Regards, malcolm.
addo
Sara Watson's Stalker
x 93
Post by addo »
I think you could distract the tester simply by waving the Wurth calendar in front of them repeatedly. :wink:
spider
x 77
Re:
Post by spider »
addo wrote:I think you could distract the tester simply by waving the Wurth calendar in front of them repeatedly. :wink:
:-D :-D
Andy.
Chlorate
Post by Chlorate »
If the car only has to be visibly fitted with a cat converter if it came with one, but doesn't need one to pass the relevant emissions test for its year of construction then why not grab a knackered one rip out the innards?
You could probably tell it doesn't work from the test results, but the tester couldn't fail it because:
1: it's there
2: the emissions are acceptable
3: without actually removing the cat and having a look, they won't be able to tell whether it's been modified.
Citroen Xantia Exclusive HDi
previously:
Citroen ZX Volcane - RIP
Peugeot 106 XN... stolen and destroyed by Kent Police :evil:
x 92
Post by citronut »
Chlorate wrote:If the car only has to be visibly fitted with a cat converter if it came with one, but doesn't need one to pass the relevant emissions test for its year of construction then why not grab a knackered one rip out the innards?
1: it's there
if its a petrol car they might be able to tell by the emissions test that there are no innards to it, even more likely if the car is late enough to be fitted with a fore and aft lambda sensor,
this might even affect the emission result on a diesel
Regards, malcolm.
