Oil filters & how to remove them!
Fake Concern
x 49
Re: Oil filters & how to remove them!
Post by Fake Concern »
VertVega wrote:I used this kind of oil filter wrench in my Xantia. After trying several different types of tools I think this was the best. It is similar as given in Chlorate's post.
Chlorate wrote:I use one of these clever epicyclic gear jobbies:
http://www.lasertools.co.uk/item.aspx?cat=375&item=5099" onclick="window.open(this.href);return false;
Will this work on a Clio Mk2 Ph 2 that has a plastic case with a replaceable paper element inside?
I intend to do this one & a Clio Mk2 Ph 1 that has a canister at half term.
VertVega
Post by VertVega »
Fake Concern wrote:Will this work on a Clio Mk2 Ph 2 that has a plastic case with a replaceable paper element inside?
No, not for the paper element plastic case filter types :(
If it's same kind of plastic case as in Xsara, C5 then you can use hex socket (was it 24 mm or 27 mm).
VertVega
Post by VertVega »
According to the YouTube video I have just watched Clio has a different kind of plastic case oil filter as in C5.
In the video oil filter change starts at 5:58 and you can see the tool used there:
and also the tool I have shown above pic. would work fine in this case :) .
Fake Concern
x 49
VertVega wrote:According to the YouTube video I have just watched Clio has a different kind of plastic case oil filter as in C5.
That's interesting, I didn't think of looking on youtube!
The last time I did it I got it off with an old bike toe strap!
